Clutch Protection Gen 6 ZL1 M6
In the Engine section under the General Tab there is a setting called Clutch Protection, you can select Disable or Enable. If this switch is set to Enable and the ECM detects clutch slippage what action will ECM take, pull the TPS or pull timing? or something else? It does make sense that will use the Fuel Cut Off controls as there are settings in this section that control the clutch and various rpm controls. Any help would be greatly appreciated, I have been fighting a bog trying to launch this car and I am running out of options
If anyone with a M6 GM car with a Gen 5 ECM is interested we were at the track last Saturday and disabled the clutch protection and this seems to have solved our bog problem, no TM issues or the ECM closing the throttle. However, we have also adjusted many other tables to get this car to launch.
