mild cam , injectors and headers.
I have my tune for 09 Challenger 6.1 manual trans - heads, heavy cam. May be a good starting place to compare your tune to using HP Tuner Compare function!
Give more specific info on mods and what your car is doing/not doing? and someone may be able to get you moving in the right direction?
I see it's a 2008 so it's auto trans so may need to be significantly different than manual trans.
Eric
Last edited by Overpowered; 09-28-2022 at 04:28 PM. Reason: Clarified To Eliminate Trolling!
lol people just sharing tunes !!! this forum is for knowledge on educational purpose of tuning with hptuners !!!!
if you want a tune spend money and hire professional tuner!!!
and to the guy who wants to share his file you're a moron, you don't know shit about his build he didn't even write his injector size how could it be good starting place ?? how do you know when he installed cam, he didn't ruin something on his old shit box harness during R n R and for you to share another tuner file with stranger you suck .. maybe your reply should've been something educational like trying bumping idle rpm and airflow table to get it to idle
Most times people will post their current tune, someone will look at it and help if they can. every tune is different , there are so many different cams out there , what you call mild might be mid .500 lift and 230+ duration.....I call mild anything under .500 lift.
Post a tune , try and be less vague in what you want.
62 Biscayne 425/409 SS/D stock class car 10.60s
66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
