adding a Channel info
I believe I may have the timing off.
Trying to use demigods advice but cant find the channel for Exhaust Cam Angle.
All I have is channel for Exh Cam clipped and Exh cam DC besides the ones he said prior.
"Go to your scanner, click on "add channel".. then go under Engine and click, then scroll down to where it says "Camshaft & Crankshaft" and click this... then scroll about midway down til you see "Exhaust Cam Des Angle" and add this as a channel. Then click on "Add channel" again... and in the same subset, click on the next one which is "Exhaust Cam Angle" and select this as the second added channel. then select the following one as a new channel as well, which will be "Exhaust Cam Error" and finally select the following one after that as well, which is "Exhaust Cam Center Pos". Then go ahead and turn the key to run and make sure you are running an active log... then scroll down to these 4 newly added channels and see what they are reading... Then start it up and record"
