Installed a BTR stg 3 PD cam in my lsa. I have a vararam intake on it. Before the cam all was well. After the install i have a decently smooth maf signal at idle but very erratic at hwy speed 1600rpm. It does smooth out the higher the rpm. It causes crazy swings in the wideband and you can slighty feel it. Is there anything that can be done to straighten this signal? It does have a honeycomb in it, but is this typical or does it depend on intake flow? Or is there a filter in the tune cuz ve is solid. Or just go SD? Here are the screen shots.
