E38 will not work in a Drive by Cable set up.
Has anyone heard (or thought) of using an aftermarket drive by wire throttle actuator with the E38?
Or see a reason it will not work?
Like this https://www.efihardware.com/products...e-actuator-dbw
Or this https://kinsler.com/Shop/2021/01/25/...ttle-actuator/
Idea is to use a vintage enderle injector throttle body (Hat) on a LS3 and maintain the E38 and GM throttle (pedal assembly)
I also though if calibration of the actuator was an issue, I could use a torque rush X2 inline.
