Has anybody seen if your enrichment rate is to high it causes small lean spikes?
Yes, I’ve seen that in some 04-05 Hemi rams, were are working on one now that commands as much as .0900 + .0694, around 1700-2000rpms only does it when the pos 545 doesn’t want to kick down to 2nd , the 02s go all the way down to 250v, and it pulls as much as 5* of timing
04 RAMGTX........ 8.91@151mph 392Ci G3Hemi 3600lbs 2.6HP/Ci Naturally Aspirated
05 RAMGTxtreme 9:45@142mph 426Ci G3Hemi 4000lbs 2.2HP/Ci Naturally Aspirated
09 Challenger Drag Pak 8.88@150mph 376Ci G3hemi 3650lbs 2.6HP/Ci Naturally Aspirated
G3 Hemi Videos
https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
