Ok guys i need some help. I have a 99 c5 corvette its a 383 stroker stock ecu car. I had been running the fast 92 with the ls2 throttle body and the car has been running perfectly fine, i just put a fast 102 with the new Texas speed and Performance 102 throttle body, which looks exactly the same as the NW 102, and now the car is throwing a few codes. Accelerator pedal position sensor code, throttle body position sensor code and a correlation code.
I really just need help on where to change some parameters around to get it to work.
