2 Attachment(s)
Injector data transfer question Gen 4 to Gen 3 Flex Fuel
I have a truck coming up with a turbo running low boost.
He put in the large 4 hole flex fuel injectors (stock 50#) out of a Gen 4 2011 Denali 6.2L.
These injectors are now installed into a Gen 3 P59.
My question is importing the data from the E38 PCM Offset - "Offset vs. Press vs. IGNV" into the P59 PCM Offset - "Offset vs. Volts vs. VAC"
We got one table using "Pressure Delta", and the other table using "Manifold Vacuum".
How is it I can import this Gen4 data, into the Gen3 PCM?
Thank you very much. :)
Attachment 118258Attachment 118259
