Originally Posted by
cbeutelschies
Hey everyone,
I recently swapped injectors from my stock 02' 28 lbers to a set of 41 lbers from a 2007 Z06. I made some adapters for the height difference and picked up a set of O rings from the LS1's so they'd mate up. The last thing to do was to correct the tune for these injectors. Unfortunately, the data format of the new PCM changed the way a lot of the tables are expressed in HPT. So, I spend a couple of hours and put a spreadsheet together that is easy to use so someone else could benefit from it.
Anywho, here's a spreadsheet that allows you to pull the stock injector data from a LS3/LS7 tune and just copy the data and paste it into the designated cells in the worksheets and it will spit out data that is friendly for the LS1/LS6/Truck PCM's.
As an FYI, the swap results turned out very well. My Injector Duty Cycles were in the 115 ish range before on the 28 lbers at WOT and after the swap, they are about 80. Rock solid 0.82 Lambda at WOT and idles like a champ.
Let me know if you have any questions about the sheet and I hope it saves someone some key crunching.
Thanks,
Cody B.
