Originally Posted by
edcmat-l1
It would be better trying to resolve an issue, if you posted a data log of it running with some of the throttle blip problems you're talking about.
Otherwise if you're just looking for a critique:
VVE can't be right. I can tell you that by the shape.
It's in "MAF only". Since that's the case why even modify the VVE?
I never turn off Cat protection if you have cats on the vehicle (which all street driven vehicles should have).
PE is pretty damn lean.
Timing is fairly aggressive.
That along with deadening the knock sensors could be a durability problem.
Minimum timing has been zeroed out at idle. That's usually an indication the person doing the tuning has or had an issue trying to control the timing at idle. That table should never have to be changed if everything else is in line.
The VT is WAY over what's in my compare file.
Intake manifold is unchanged. Are the stock intake for the vehicle and the L86 the same volume? I don't know either way but if it's different it needs changed.
