The Timing table uses cylinder airmass as it's load variable while the VE is based on manifold pressure. The Axis cannot be adjusted to match simply because they use two totally different parameters as measurement of load.
You are quite right about that--I misunderstood the question
No.
3.2 seems to always open as a small window, while other versions used to open as I last closed them. Is that for everyone or is it something on my end. Just wondering.
If you're using an older version side by side, your settings will not work as expected.
3.2 should remember your size and location correctly.
Just played with it a little further.
I am not running any older versions. Whats strange is it opens about 8"x8" and will reopen in the same place I close it last. If I expand it to full screen and then close it, it reopens full screen. It will only do those 2 things. If I use half the screen for example, and then close it, it opens as a small window again. It wont remember unless its full screen. All previous versions opened exactly as I closed them, which for my is about 3/4 of the screen used.
Are you using a multi monitor display, or anything unique to your setup?
Keith,
It behaves the same way on my dual monitor desktop and my normal laptop. On both it only remembers previous size if full screen. If I close it while taking only part of the screen, it reopens as a smaller window near the center.
Both are running windows 10
So I am also tuning a 2015 C7 LT1 stroker with a supercharger and it too will not get into boost with a failed MAF.
So the two variables here are 2014 (which worked) vs 2015+ or something to do with 2.2x vs 3.x
Still hitting my head on the wall here, if there is any solution it would be appreciated.
I think if you right click on your icon ,propertys you have the choich of what size window it opens in.
We're looking to put that fix into 3.4
Will this update support 2016 Chevrolet Cruze 1.4T? A coworker has a loaner and thought I'd copy the file with v3.0 and it would not recognize anything.
I can try again Thursday or Friday if this current update will work. If not can I help getting a copy to someone?
3.2.20, E40, 2005 vette: Alcohol percent is not displaying in the scanner channel list. The channel is there but the value is blank. Thought it may be a problem with my ethanol sensor retrofit but 2.24 displays it properly.
Updated to latest build, 3.2.25 with same behavior.
Did you use a 2.24 config or add that channel In 3.2? I know it works in mine, I'll post my channel list in a bit to see if it works then
No my channel list in 3.2 was initially created in 3.0 and was working then. Attached is the channel xml
Also if I open an old 3.0 log in 3.2 it displays properly.
