when i try the kpa to psi thing it does not read correct. but im also trying on a 3bar sd. how do i get it to work.
you can put on the function -9 you can change the 9 if it is still showing more boost than what it should you need to up the number (9.5,10,10.5,ect.) if it is showing less boost than what it shoud you need to lower the number (8.5,8,7.5,ect.) let me know what works for you because im new to all of this and just trying to learn everything and also what is it on and is it s/c or t/c? -9 worked on my car thats why i told you to try that good luck!!:)
Tc.
i get that the site is down... anything new???
ok cool man ill keep checking back
The "Basic Scanner Startup Demo" link is broken. Did that get moved somewhere else?
Thanks, Jon
These are very helpful, but when I tried to do the "new" converting MAP kpa to psi video, it keeps telling me that I need to turn on macro flash or download the newest version from the link. I have tried to download it and play it in both firefox and internet explorer, downloaded from the link and I am still unable to view it.
Edit: To add to this it seems that none of the ones created with camtasia studio or whatever will run. Some of the new ones work, some do not....not sure what the difference is.
I am also still having this issue.
J. J.
Is anyone still paying attention to this???
J. J.
I am, Just ordered my HP Pro kit, and Im new to all of this. My 87Grandnational seem prehistoric campared to this, but to learn. Got a 1981 Turbo T/A with a 2001 LQ4, Turbo swap.
All cleaned up, went through the remainder of the files and removed any that were not functioning properly.
Ok, please list which demo's you guys want posted again, finally got the server issues worked out so I have most if not all of them on there so just need to know which ones to post rather than going through all of them.
hey bill, i upgraded to the 1 bar sd enhancement on my 02 camaro ss mainly to use the rtt feature. i have made sure to properly select what i want to use in editor, flashed, and as soon as i try to use it in the scanner it force closes with an error message. yes i have sent the email to support. any ideas what i am doing wrong? i would imagine using rtt is pretty straightforward and would not need a demo video, but then again i have never used it so i dont know.... any searches i have made for rtt have given very little results. rtt is mentioned a lot, but no instructions anywhere!!! thanks for any help, or thanks even if you tell me to pack sand, bc i still love hptuners! lol
updated to 2bar ds, but the axis values do not match to the demo. it starts at 30kpa and increments by 10 kpa instead of 5kpa. how do i change the axis values to coinside the video?
U can't they r hardcoded.
