2 Attachment(s)
Injector Data 12613412 Gen 3 PCM
Hey guys, Just wondering if someone could share a tune for 12613412 Injectors. I need to convert it for a gen 3 computer. The files I've found already that have been converted are sorta all over the place.
Here's what I have so far - Attachment 129884
Here's One file I was comparing to - Attachment 129885
Somewhere on here, there is an excel Sheet that converts LS3 to LS1 data, I used that to convert the data I found from a stock tune (or so I assume) that had 12613412 injectors
Notice the fuel tables vs voltage and flow rates vs intake vac are different.
Does my fuel Data look right (edit - Looked at a 3d chart and something is def wrong) ? Does anyone have a stock tune file for a vehicle with these injectors or even better a converted fuel data for a gen3 to compare to?
edit - Forgot to ask but I've seen guys online only change fuel flow rate data (and very roughly) when swapping OEM injectors. Can ou tune perfectly fine without worrying about injector data? Is it more of a thing you do so you don't have to redo MAF and VE if you swap injectors latter?
