Can I add rows to the timing table? Also what might be pulling timing?
Car is a Supercharged Camaro SS and I'm pulling more Airmass then what is listed in the main spark advance table. Can I add rows to cover higher airmass? Or do I have to just adjust some of the numbers a bit higher to cover the added airflow from the supercharger?
Also I called for 15 degrees and was only seeing 14.5, after a bump to 17 degrees i was only seeing 15.5-16. Car isn't seeing any knock, intake and coolant temps were good and the afr was in check.
