Originally Posted by
eficalibrator
Guys, please keep in mind that this scaling method still has some limitations. It does not address either the 512g/s total airflow limit or the 1.28g/cyl limit present in many GM ECMs.
Chances are that if you are legitimately making enough power to need injectors bigger than 8.0g/s flow rate, then you probably also have an engine capable of flowing more than 512g/s (about 650hp, give or take). If you run into this limit, the ECM will still drift lean at the top end unless you opt for the more involved method of scaling fuel flow, ALL air flow/mass values (g, g/s, g/cyl), and torques. This method has been discussed on here previously by myself and James (RWTD). There is also a great demo included in my Advanced GM Tuning DVD (Summit part# SME-DVD-2) where I show the before/after results of scaling side by side on a split screen.
