Hey guys! Anyone have a way to connect your wideband to the MPVI2 and see it in VCM Scanner?
NO! 2 Weeks!
You can use the AEM wideband that we sell in our online store on most CAN based vehicles, but if you are looking for an analog input solution it is still in development for the MPVI2
Thanks for the answer Bill, it seems Blue Bee is trying to mislead me :crazy:
Will the can based wideband work on an 2007 Yukon Denali?
If the OBDII connector, on your vehicle, has the CANH (PIN6) and CANL (PIN14) pins installed, you very likely have a CAN based ECU.
It must have BOTH pins.
Attachment 82247
My 2007 Sky Redline has CAN. So, it does happen. I have not seen it on anything prior to 2006, though. Everything 2008, and later, should be CAN.
One option is to hard wire it into your ECU using the EGR sensor circuit. https://forum.hptuners.com/showthrea...nd-through-EGR
Thanks for the info guys
Ok so If I run the aem x series obd2 wideband with the mpvi2 I should be able to log afr?s on a 2007 srt8 Charger correct? I?ve been debating on trying to find a mpvi for sale so I can log afr?s for my tuner but if it?s possible with the aem and the mpvi2 I?ll go that route.
Which of the above pictures ( from post #6 ) does your car's OBDII connector look like ?
If it looks like the "CAN based ECU" connector, you should be good to go.
By all means, share. But, I'm sure somebody can make a better pic than that :)
I wish I had a solution for the non-CAN guys. But, as soon as I could get it out there, the PRO/HUB thing would be ready.
I upgraded to MPVI2 over a year ago, and at that time my LC-1 wideband would work in my scanner. Since then my laptop died, got a new one, and downloaded the new 4.6.0 VCM SUITE. Now my LC-1 will not work with the Scanner, and no one seems to have a solution.
And I am not purchasing the AEM wideband sold by HPTuners just to solve this problem.
Bill, please get this fixed so that I and other users can utilize their widebands with MPVI2. Thanks
Pro feature set + MPVI2, been out since 2018 https://forum.hptuners.com/showthrea...ure-Set-Update
