Page 1 of 5 12345 LastLast
Results 1 to 20 of 88
Thread: MpvI3 and Jtec+
    Apr 2020
    18
    MpvI3 and Jtec+
    Apparently the MPVI3 I ordered isn?t compatible with my 2002 Jeep Wrangler 4.0 any ideas about when a update will be available I find it a bit stupid that a newer version wouldn?t be as compatible as an older version.
    I almost ordered a MPVI3 for my 2001 Dakota (JTEC) and asked them if it was compatible. One response from HP said I could use MVPI3 and another said it wasn't compatible yet. They said I had to order a MPVI2+, which are out of stock. They really need to do a better job advertising, no where that I could find said the MVPI3 wouldn't connect to JTEC.
    Attached is the post where they told me MPVI3 wasn't compatible with JTEC and JETC+.
    https://forum.hptuners.com/showthrea...1-jtec-and-HPT
    Apr 2020
    18
    I had an mpvi2 and it was stolen. I just purchased the mpvi3 and from all I could tell from the website it would work on my 2002 tj. Why would they introduce a newer version with less compatibility?
    Apr 2020
    18
    They are working on an update to fix this issue.
    Oct 2022
    3
    Does anyone have any idea on when it may be fixed?
    28,288
    Quote Originally Posted by Zbaker888 View Post
    The hope is to roll out a fix for JTEC late next week if all in house testing goes well.
    Aug 2017
    Quakertown PA
    481
    Thank you Bill, I’ve been holding off on the mpvi3 because of this, ....... off subject, & I don’t expect an answer , the 03 Hemi trucks? Any hope, any suggestions......other then what we have been doing, ((swapping ecu to 04+
    G3 Hemi Videos
    Oct 2022
    3
    Well I needed one asap so I bought an mvpi2 I would love to be able to return the mvpi3 to hp tuners since they falsely advertised that the mvpi3 was compatible with my vehicle when it is not.
    Hello Bill,
    Could you please reply to this post when MPVI3 can support JTEC. Thanks
    28,288
    Yes
    Oct 2022
    Oklahoma
    24
    Gosh I wish I'd have seen this earlier. Used my MPVI3 yesterday to read, make minor modifications, and then it erased and failed to re-write a 99 Ram JTEC+ resulting in a no-start situation for the pickup and no-bus read on the cluster display.
    Hoping the fix will allow a proper recovery via MPVI3 without having to have it recovered via other methods.
    Hate that my first post has a negative tone, I've been using HPT with no issues on GM trucks. Should have done more research to see real-world results on JTEC(+). That's my own fault.
    Apr 2020
    18
    I did the same on my 2002 jeep tj. Cleared all dtc?s then proceded to read the tune and tried rewriting another tune I had and it failed, now it only cranks and wont start.
    Oct 2022
    Same thing here with MPVI3 I worked on 99 Wrangler (JTEC+), made changes to the read file and then it failed to re-write it. I never thought that the newer device doesn't support old stuff, what a disappointment.
    Oct 2022
    Oklahoma
    24
    Sorta begs the question as to just how much testing occurred BEFORE releasing the MPVI3.
    I understand the process is detailed and tedious, but when we're sitting on vehicles that were stated to be supported, and gave no indications of failure until said failure causes undrivable vehicles, the purchase price is assumed to have included the necessary due diligence in product testing before release.
    It's a good thing this was a family member and not a customer, in my case.
    822
    Quote Originally Posted by Westbankfireman View Post
    Welcome to non-GM tuning.
    Oct 2022
    Oklahoma
    24
    Thanks, I think.
    Mar 2021
    ohio
    31
    anyone is the southern ohio area that is in need up help with no start due to failed writing please contact me i may be able to help as i have an mpvi2 and can flash your pcm with a file to help get you back on the road you buy the credits of course.
    01 dodge dakota 5.9 swapped nv3500, ported stock heads, m1 intake, 220 220 custom grind comp cams, 10.3:1 compression tuned by me with hp tuners.
    15 jeep jk 3.6 lifted on 33s 87 octane custom tune by me with hp tuners
    04 dodge dakota 4.7 air ram heads, 08 cams, 08 intake manifold, 10.5:1 compression, 341whp custom tuned by me with hp tuners.
    Jan 2023
    Yes
    Hello, Bill.
    Any updates on this? Want to get an MPVI3, but not until JTEC is fixed.
    Thanks,
    Aaron
    Jan 2023
    Partial answer to my own question:
    https://forum.hptuners.com/showthrea...Jtec-B-support
    Alpha support was released, not available in beta or full release yet that I can find.
