Results 1 to 8 of 8
Thread: 2008 ngc4 Pcm swap
    Sep 2021
    Yorba Linda
    84
    2008 ngc4 Pcm swap
    Hey everyone i went from a ngc3 pcm to a ngc4 in my 1973 Dodge Challenger with a 6.1 545rfe combo . I got everything in order except it has a cold start syndrome all the time. I understand its ok when cold it goes to about 1400 ish rpm and gradually comes down to idle within a 2 min or so . But its annoying that it does it all the time , even when its warm . I thought they had a slight idle and came down to idle right away when warm . Is there anyway to fix this ?
    Thanks guys ! You all have been super helpful ...
    Sonny
    Quote Originally Posted by Hpsonny View Post
    Sonny
    Firstly I would use the beta scanner to reset your tb. If that doesnt remedy the issue.. You could lower your commanded rpm a bit in idle tables
    Sep 2021
    Yorba Linda
    84
    Quote Originally Posted by luciddeath View Post
    Ok i messed with it yesterday and was in the Idle speed runtime adder p/n section and messed with that .. It lowered it on initial start up to about 1200 and gradually came town to its desired idle of 672 however i’d like to see it when warm get to its idle faster and not hang that idle like that . When it’s cold or first start i don’t mind just when it’s warm . i only messed with that one table and it seemed to change it up so now if i can just make it start up , idle up and down right away that would be great . Also i do reset my TB every time i flash it
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    481
    You might want to change the row axis to different ECT values,
    04 RAMGTX........ 8.91@151mph 392Ci G3Hemi 3600lbs 2.6HP/Ci Naturally Aspirated
    05 RAMGTxtreme 9:45@142mph 426Ci G3Hemi 4000lbs 2.2HP/Ci Naturally Aspirated
    09 Challenger Drag Pak 8.88@150mph 376Ci G3hemi 3650lbs 2.6HP/Ci Naturally Aspirated
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
    Sep 2021
    Yorba Linda
    84
    Quote Originally Posted by PurpleRam View Post
    Which ones exactly ?
    Advanced Tuner rays04gtx's Avatar
    Oct 2021
    Allentown PA
    363
    Here's your 35502 table stock, and then modded, if you click where it says engine coolant temp on the side, those cells are "changeable" just set them to new Temps for the idle to target.
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
    Oct 2021
    Allentown PA
    363
    the other thing to do is to modify 35543 , click on where it says Engine run time (S) , you can change those values to any seconds you want, ....so as is , it's
    2.6(seconds) 12.8(seconds) 25.7(seconds) 38.5(seconds)51.2(seconds)
    then click on the side of the table where it says Engine Coolant temp and you can modify those values to what you want....
    -4(degrees)
    32(degrees)
    68(degrees)
    140(degrees)
    376(degrees)
    Remember to match all ECT values in each table you change. (in the Idle RPM section)
    Play with it till it does what you want.
    Sep 2021
    Yorba Linda
    84
    Ok i got my trans in and it seems goood so far .. messed with the run time a bit and it still kinda hangs for a bit just not as much rpm
