Results 1 to 5 of 5
Thread: 97 K3500 L29 with 0411 swap, I want to eliminate ABS system
    Oct 2021
    38
    I'm in the process of swapping in a new L29 454 engine with ported heads, reground cam, Edelbrock pro-flow manifold, injectors, and throttle body, and making it work with a 0411, currently with an L31 tune in it. I want to eliminate the ABS motor system under the hood and go with a Wilwood conventional proportioning valve. What needs to be done in the pcm to turn off the abs system?
    13,582
    Nothing. The ABS is not part of the PCM controls.
    Oct 2021
    38
    Ok thanks. There will probably still be a brake error light to deal with.
    1,533
    Yes brake light will still be on. Sometimes you can open the cluster and cut the trace.
    Aug 2019
    Greenville, MI
    58
    I eliminated my ABS as well.... Pull the cluster out a bit and take out the bulb. That is the only option.....
