Hello Has anyone deleted the MDS on a 2019 ram Hemi with hp tuners
I have deleted MDS in a number of charger/challengers by simply disabling the function in the tune. You can keep the stock cam and MDS solenoids in the car. For the trucks, I would imagine it works the same.
62 Biscayne 425/409 SS/D stock class car 10.60s
66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
To disable you certainly can do that through the tuning. To delete it you need to pull the heads and replace lifters as well as cam, then disable in the tune.
