Results 21 to 40 of 50
Thread: "DE-Tuning" 2005 Hemi - This should be a first !
  1. #21
    Nov 2019
    227
    Quote Originally Posted by LilSick View Post
    I dont think the IAT dropping from what is your avg? 85? to -4 does anything to the fueling.
    The fueling strategy is still based on the SD algorithm and intake air temperature is one of the key parameters to calculate the actual air density.
    Calculating the air density for 85F (30C) and -4F (-20C) for dry air at 100kPa (approx MAP at WOT at sea level) you get ~1.15kg/m3 and ~1.37kg/m3 respectively.
    Therefor the air density will be over estimated by approx 19% and thus the fueling will go rich by a similar amount to match the over estimated air density.
    [ECM] 44280 - VE IAT Factor would be the table to tweak this if it becomes an issue using this strategy.
    The
  2. #22
    Mar 2019
    Ontario Canada
    34
    Thanks again everyone - so question becomes - with the low - -20c IAT - cause a change quick enough , or will PCM ignore this change and/or use an averaging approach.
  3. #23
    Jan 2022
    910
    Will changing the temp from 68 to 85 for the PT reference spark change the open loop fueling by changing what the VE is based on?
  4. #24
    Advanced Tuner rays04gtx's Avatar
    Oct 2021
    Allentown PA
    363
    no, open loop is
    Engine>Fuel> Oxygen sensors, Table(S) 2460,34450,44539,34454 Max values out.
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
  5. #25
    Oct 2021
    Allentown PA
    363
    Wow so those tables control timing voltage and amps? So if for instance if the pt ref is IAT 20c (68 deg f) and your IAT's are actually 30c 85f what does that do to voltage and amps?
    Table 44664/44665/44663 are the Temperatures the spark plug amperes are referenced to, the Higher the temp the weaker the spark, it's not a trigger point, it's not a way to change heat range.
    Ric(Purple Ram) and I spent a few hours yesterday trying to see if we could use Cold Launch(table 12675) to some how trigger and pull spark(see attached ) we tried a few different temp settings , RPM Windows, cut up a nice 05 Ram Wiring harness, several different resistors, even tried a dimmer switch.......... ..........Nope No Go .
    Once the ECU is on to WOT tables there NO WAY to get them off those tables unless you lift your foot to drop TPS voltage, only the Knock Sensors cam pull timing while on the W.O.T tables......(Hint Hint)
    I spent the better part of the morning talking with the 68dart owner referenced earlier in Ric's post, he said the IAT trick never worked out for him, he wound up using a trigger switch on the BARO voltage to trick it in to hitting 70KPA as the RPMs drop to their recover point from the shift.
    I've made a few comments(in different threads) about my Middle son Benny , he worked for DCX/FCA from 01-19 , he was on the team that wrote the ECU programs for the Hemi , we bent his ear last night , and Benny says ........NO , on the NGCx ECU's the IAT's only function is to help determine the quality of air, (like Hasesxp states) all NGCx ECU's use MAT for spark calculations PERIOD,
    ECT Spark tables are triggered by Table 44661/44662/44663.....but again, once the WOT tables are triggered the ECU will not step down till the TPS Voltage drops below it's trigger point.
    Now Benny says the one option none of us have thought about is Knock Voltage,( sooooooooo) We played with that concept for a bit and YEAH!!!!!!!!!!!!!!! we got it to pull timing based on jumping Knock Voltage to 5v at shift point to trigger table 44701 which we also rescaled ******** Important point, make sure ALL Retard tables have the same Value , we used 6* degrees as a value , we managed to get the system to pull from 24*s at WOT to 18* when 5V was triggered. again the Important point is to make all values = , it was the only way we could get constant results.
  6. #26
    Jan 2022
    910
    These Hemi need to be pulled back to 0 deg or darn close or they are still gonna drive thru the clutch pack
    Does not seem that going from 24 to 18 (or from 20 to 14) is gonna help
    [email protected]
    don tanklage
  7. #27
    Oct 2021
    Allentown PA
    363
    RFE545 maybe , but a well built 904 will do 600HP in 3500lbs or Less with ease, the 05 ram that Purple Ram talked about in post #2 had a John Cope built 904 in it , truck weighed 3800 was solid 580HP 10.90s @122-125MPH 362CI G3 , never pulled any timing on that combo, ran 24* from 1600-7700 RPMs on the 05 ECU , truck had a total of 105 passes on it before the 441& lenco ST1200 went in it.
    My Brother and I campaigned a 68SS/AH Hemi Dart for 4 years , the trick to those is running 904 sun gear and a few other 904 parts in a 727 case, those cars are 3k lbs between 1050-1100HP , yes the trans has to be rebuilt after each track session, we would get 12-20 passes on one of those hybrid trans, replace all soft parts and go at it the following weekend.
  8. #28
    Nov 2019
    227
    Quote Originally Posted by rays04gtx View Post
    Them NCGx ECUs must be quite different to the GPECs as I regularly use the IAT and ECT hot/cold spark tables to remove/add timing, especially to remove timing on boost applications at WOT once the IATs starts to climb.
    Nice trick on the knock sensor voltages!
  9. #29
    Jan 2022
    910
    yeah except the op basically has a 904 w o.d. so with the right valve body he will be fine shifting it at wot lol does not need to pull power
    plz explain how knock voltage would work if he did? How can you make knock sensor sensitive enough to pull 20 deg when 5v present and not have it pulling 10 when ya dont want it pulling anything?
    [email protected]
    don tanklage
  10. #30
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    479
    You would want to set it up like the gm guys do with IAT,
    The ram we used had the knock sensors removed a while back, I wired the leads to a on/off switch to trigger the ECU , we used 6* as a start/test value. Doesn’t matter what value you use….
    Hassexp, ngcx is Stone Age compared to GPEC
    04 RAMGTX........ 8.91@151mph 392Ci G3Hemi 3600lbs 2.6HP/Ci Naturally Aspirated
    05 RAMGTxtreme 9:45@142mph 426Ci G3Hemi 4000lbs 2.2HP/Ci Naturally Aspirated
    09 Challenger Drag Pak 8.88@150mph 376Ci G3hemi 3650lbs 2.6HP/Ci Naturally Aspirated
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
  11. #31
    Aug 2017
    Quakertown PA
    479
    Quote Originally Posted by HaasExp View Post
    there's one 05 I tuned a few years back, with a 416CI(5.7 based, 4.03X4.08) , all timing tables are set to Max 26* if it's a table that has timing, it's set to same values as the WOT table... but yet , I have 25 out of 130+ logs that shows it will hit 27* on deacceleration when the TPS is @2.27-2.28 , MAT is 100,IAT is 90F and ECT is 183F, it will not hit 27* if any of those values are different, all 4 factors have to right....
    Benny has said a few time that the IAT is just about useless on the NGC's , because DCX officials felt that the End users would place the sensor in other places( like the Magnum guys would do) so MAT is the main temp source for emissions reasons
    G3 Hemi Videos
  12. #32
    Mar 2019
    Ontario Canada
    34
    LilSick - even worse A606 transmission.
  13. #33
    Mar 2019
    Ontario Canada
    34
    Thank you again for your comments and research !! Currently trying another route as well. Fool accel pedal voltages during shift , so PCM thinks driver has taken foot of the gas. To save transmission , I have been doing this while driving the car. Not good for anyone else though !!!
  14. #34
    Aug 2017
    Quakertown PA
    479
    Ahhh 42LE makes sense Now........................I didn't think you could bolt a Hemi up to the "606"
    https://spprecision.com/products/42l...yABEgKpVPD_BwE
    G3 Hemi Videos
  15. #35
    Jan 2022
    910
    What did you do??? Did you put a gen 3 hemi in a front wheel drive mini van???
    [email protected]
    don tanklage
  16. #36
    Aug 2017
    Quakertown PA
    479
    I was thinking maybe a prowler, when we did my cousin’s SRT6 we used a 904 , there’s a prowler with a t56 behind a SRT8 crate engine, I see that once in a while at some local cruise nights
    G3 Hemi Videos
  17. #37
    Mar 2019
    Ontario Canada
    34
    Bingo - Hemi Prowler. www.hemiprowler.com
  18. #38
    Aug 2017
    Quakertown PA
    479
    Just awesome.
    G3 Hemi Videos
  19. #39
    Mar 2019
    Ontario Canada
    34
    rays04gtx -- sent you a PM !!
  20. #40
    Mar 2019
    Ontario Canada
    34
    Well the weather is finally good enough to do a real test drive. Car was just up on blocks before.
    Regarding the Torque Management issue, I am testing fooling the APPS with a couple of resistors to simulate reducing throttle pedal position. Seems to work but am getting a DTC P2138 - APPS Voltage Correlation. I need to refine my resistors !!
    Todays question is - Engine idles at approx 2000 rpm when I am coasting to a stop sign , foot off Accelerator Pedal. When I actually stop (or just before) RPM drops to 624 rpm just like is set in the idle tables. On a 2800 lb car, 2000 rpm is enough to keep it moving and you really need to use the brakes to stop. On startup, engine starts and immediately drops to 624 rpm as expected.
    Any help is appreciated ! Thanks .
    2004hemi-rolling-high-idle.hpt
