Results 1 to 18 of 18
Thread: 1.4T ZZP Stage 1 cams
    I have their 1.4T LUJ/LUV stage 1 cam lying around in the garage waiting to be installed in the next two weeks.
    But before i do, does anybody have some information on them? I mean intake and exhaust angles, at least the basics.
    I contacted ZZP themselves but they were really not helpful, as they require me to buy their custom tune to get all the tuning data for them.
    I know the clearance at 0 degrees intake and 30 degrees exhaust and 30 degrees intake and 0 degrees exhaust is just fine on the stock camshafts, and the valves will not touch the pistons.
    What about the ZZP ones? I assume that should also be the case, else custom tuning is going to be a big nightmare.
    Aug 2016
    384
    Good luck, not sure how zzp did it, but there's a bunch of tables and parameters that don't exist in the editor to calibrate these cams correctly. The valve event timing appears to be the same as OE, but the duration is longer, obviously, because its high lift.
    Dec 2008
    Nevada
    4,450
    you would have to sacrifice a set of cam phasers and degree them in at full stops to know their position information. Same test can tell you piston clearance if you set measuring equipment up correctly.
    I don't think you'll ever get that level of cam information out of ZZP.
    Quote Originally Posted by tunerpro View Post
    There's indeed some interesting tables in the ECU for things, but no worry about that. I'll email hp tuners support to add them to the software when i find all the definitions.
    Yesterday i found a whole set that enables when and how scavenging is activated. Turns out my stock ECU doesn't even use it, which explains why i get full boost at 3500 rpm on a bigger turbo.
    Aug 2016
    384
    Quote Originally Posted by cobaltssoverbooster View Post
    Yeah, we used an old school cam degree wheel and a dial indicator on a spare engine we had to sort it out... Even that's not 100% accurate, but it gave us enough information to sort out what they did.
    Funny thing is at one time ZZP actually had the duration and lift specs for the new cam. The exhaust side is just a flipped intake cam. That cam has more lift and somewhere around 10* more duration than the stock exhaust cam. There stage 1 intake cam has more lift and duration than a stock intake cam. I have them in my cruze and it absolutely screams. The biggest thing done to adjust for them was retard the intake side 5* at low rpm and airflow. Then changed the startup intake cam temp to 100*f and the angle to 5* to get rid of the lope at startup.
    Quote Originally Posted by jmardlin View Post
    Thank you very much!
    Also if anybody is interested in alternatives, dbilas dynamic from germany has camshafts, springs, injectors, conrods and pistons for this engine.
    Jun 2022
    27
    dBilas is 50km far away from my home
    Maybe the user derTobi, which is from the company EDS in germany, have them, too.
    ZZP camshaft has been installed, together with valve springs and retainers
    The K04 turbocharger spools on the stock cam at 3300 RPM, on the new camshaft it spools at 4200. It seems very happy at 1.5 bar of boost. This is on the stock conrods and pistons. Lacks tons of torque below 4000 tho, it's like a generic 1.6 N/A i'd say now ��
    Dyno time to be booked soon, together with proper cam angles.
    Heck I run mine mostly on E85 and get up to 265 kpa on the map sensor. At my altitude that equates to 163 to 164 kpa of boost. She absolutely screams with the zzp cam, valvesprings and a big wheel V3 turbo.
    Feb 2019
    Stockton, CA
    198
    Trifecta has an article on their blog about their experience with tuning that particular cam for the LUJ and the LUV. Just go to the website. It's in their blog. I just read it the other day and it offers a lot of insight for the stage one cam and what goes into installing it and what you need to do to tune it so it works right
    DARKFALL COMMISSION
    Performance Calibration & Module Customization
    Specializing in Dodge and GM vehicles and their respective control modules:
    Dodge PCM unlocking (and many other types of unlocks), programming for Hellcat swaps & conversions
    (ALL modules. Even locked ones. RFHubs, BCMs, etc. Locked doesn't apply to me. haha), tuning, standalone setups, and more.
    Pretty much whatever you can think of for GM and Dodge.
    IG/FB: @darkfallcommission
    Quote Originally Posted by RoninDusette View Post
    Their post is next to worthless from a tuning perspective.
    Ended up using Emu Black standalone ECU and doing it there instead for unrelated reasons, but here's the current cam angles i am using.
    Both cams retard up to -60 degrees. When the engine starts, both of them start at about 0 degrees. So you can translate it to correct numbers in hptuners.
    200-220 g/s of airflow compared to the stock turbo and cams max 130 g/s, at 10 degrees of timing and 1.3 bar (18.8 psi) of boost. No horsepower numbers yet (no dyno), but it results in 14.5 - 15 seconds from 100 km/h (62 mph) to 200 km/h (124 mph) in a 1300 kg (2866 lbs) car. 100 RON fuel, 0% alcohol, still very knock limited.
    Measured with a dragy.
    Feb 2019
    Stockton, CA
    198
    Quote Originally Posted by sbarisic View Post
    So I'm trying to dial in my zzp cam and I'm just having a hell of a time. I have a brand new bottom end so stock AC Delco crankshaft and connecting rods and I went with a somewhat of an off-brand but got really good reviews for Pistons but they're still stock compression. They're supposed to be quote better than OE. So far I don't have any problems with them. But let's say for all intents and purposes a stock bottom end. I have zzp head studs zzp cam 80 lb springs From bnr And titanium retainers from zzp and a rocker guard installed. Also have a Max speeding rods eBay" upgraded turbo which actually is different than the stock one for sure and it seems to make good power up top. My problem is I live somewhere where there's a lot of hills and I don't mean just hills. I mean we live in the mountains. I have a problem where basically everything under 2000 RPM is completely gutless. I can't even make it up my driveway in first gear. When the vehicle comes under heavy load and it's struggling to get uphill before I need to downshift and do another gear to get my RPMs higher it'll like it feel like it has no power like none like it's struggling and then when I downshift it kicks out a whole bunch of black smoke and it just does it for a second. But I'm assuming this is blow-bye from excess pressure in the cylinders or something to that effect. I guess my question is what can I do or what can I set my high barrel cam timing too in order to have it make power like a normal cruise would cuz my cruise before wouldn't have a problem making it up this driveway but it's completely gutless down low and I know it has to do with the cam timing. I just can't figure it out for the life of me and I don't want to keep doing this to my motor while I'm trying to test it out. So if anybody could post up like what their zzp cammed tune has as far as the part throttle, cam timing or anything related to the Canon timing. If you can even share your file with me that would help me out a great deal cuz I just got to get this figured out ASAP because I have to start daily driving this thing and I'm just struggling to get this thing dialed in on the bottom end
    DARKFALL COMMISSION
    Aug 2008
    Wyoming, MI
    15
    Email me your file and I can import the cam tables and email it back to you.
    [email protected]
    ZZPerformance.com
    '16 ATSV m6 10.34 @ 134 mph
    '15 Sonic RS m6 1.4L 330whp
    '04 F150 5.4 SC dune truck
    '17 Raptor stock, for now
    '00 Grand Prix GT turbo 10.92 @ 125 mph
    Feb 2019
    Stockton, CA
    198
    Quote Originally Posted by Turbo Tim View Post
    [email protected]
    Sent you an email a few minutes ago.
    DARKFALL COMMISSION
    Oh man... i'm happy when this big turbocharger spools at 4500, usually it's later... but that's up to my current restrictive exhaust setup.
    You can try playing around with the scavenge mode in the original ECU. There's some hidden tables, you can tweak how long and how soon it kicks in.
    Feb 2019
    Stockton, CA
    198
    So I had this maxspeedingrods turbo with my zzp cam spooling up and making power WELL before 4500. Like full spool at 3600 and dropping the more I worked on it. This was before Tim sent me the tune file with the data I needed.
    Look at your P.I.D. tables in the section for your turbocharger. I used that, the wastegate DC to get it to ramp up quickly, but it's also in your cam timing. I haven't had a chance to play around with it for a few weeks, but I know you can get bigger setups with this cam to spool MUCH earlier.
    DARKFALL COMMISSION
    [email protected]
    I wish I had those cam tables just to compare to what I did on my 15 to see how close I came to what you guys did. Mine runs pretty good and pulls like a freight train from 3500 to 6500 where I cut it off for safety. Funny thing is I'm just a few hours away from ZZP on the east side of the state.
