Results 1 to 15 of 15
Thread: 2012 Challenger 392 with TVS2300 Magnuson / need stock Hellcat tune as a guide
    Jun 2021
    Taylors, South Carolina
    30
    Hey, I have a 2012 Challenger 6.4L 392 with a 2.3L Magnuson Supercharger on it. I'm trying to tune but learning at the same time.
    My tune seems OK but im sure im leaving alot on the table.
    Does anyone have a stock or better Hellcat tune I can use to give me some ideas?
    I would be more than thankful.
    I would get pro tuned but I want to learn and the current setup will only be there 6 months max.
    I'm building a new 2021 based 392 with all forged internals and a 3L Whipple.
    I also have a 2016 Charger x cop car that a 2018 392 with MDS delete and a stage 1 supercharger cam is going in with the Magnuson off of the Challenger. The Charger has a good running 5.7 but I don't like anything under 6 liters.
    Truck = 6.2L
    Challenger = 6.4L
    Charger = 6.4L (soon)
    Thanks,
    PACMAN
    Mike Banks AKA Pac-Man
    2012 X-Police Challenger R/T with a swapped 392 and Magnuson Supercharger (My Toy)
    2016 X-Police Charger 5.7 but soon to get a supercharged 392 too (My Car)
    2011 X-Police Ford F250 6.2 4X4 (My Truck)
    2007 X-Police Durango 4.7 4X4 (Middle Daughters Truck)
    2019 Chrysler 300 3.6 (Wife's Car)
    2004 Neon SXT 2.0 (Youngest Daughters Car)
    2012 Nissan Cube (Oldest Daughters Car)
    Ok Ok, I got a thing for X-police cars and police auctions.
    Oct 2005
    baton rouge la
    411
    DMS Hellcat stock.hpt
    Here is a stock file for a 2020 Hellcat Charger.
    I will let you know the OS for the HC is a bit different than a non hellcat, so there are probably plenty of tables that your car will not have
    Mar 2021
    Pompano Beach FL
    265
    Sorry to say but a hellcat file will not help you at all, totally 2 different systems,
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    Jan 2022
    908
    Quote Originally Posted by ArcadeMike View Post
    Hey, I have a 6.4L 392 with a Supercharger.
    My tune seems OK but sure im leaving alot on the table.
    You put a sc on a 11:1 motor that has minimal ring land above the top ring of it's cast pistons
    What are you using for fuel?
    [email protected]
    don tanklage
    Mar 2023
    14
    hey i just put a gen v whipple on my 2022 6.4 do you have a file that i could use for a base?
    Jun 2021
    30
    Hey, its for a 2.3 Magnuson. im trying to get part throttle to richen up some but its a decent starter.
    Mar 2023
    14
    Ok thank you. So right now my car will start but dies within 2 seconds so I?m guessing me injector data is flawed somehow as I copied and pasted from a stock hellcat file. Whipple said the kit has stock hellcat injectors mid length and a 3 bar map sensor also from a stock hellcat I will copy injector data from your file and see if it will run. Any advice would greatly be appreciated.
    Jun 2021
    30
    Check the FA Stoich. In the hellcat it was something around .0755 and mine is about .0670. Let me know if that helps.
    Dodge runs Fuel/air ratio vs air/fuel ratio so I have that screwed up. I was going the wrong way with adjustments. Im going to change to .700 and update.
    Jun 2021
    30
    REDO 6PSI 20 hellcat.hpt
    Here is my current tune. Remember I really have no clue what im doing but its running and driveable so far.
    I still have to go up on the stoich but other than that it should start. Mine is a Magnusun 2.3L. I have a 3.0L Whipple in the house for the new motor im building. With me working 12hr a day 7 days a week the motor and Whipple will be finished by May 2027.
    Mar 2023
    14
    i see it says 5.7 for engine size in tune?
    Jun 2021
    30
    Hey,
    It was originally a 5.7 but I put in a 6.4. If I change it just to say 6.4 all the other modules freak out. The ABS, Traction Control and Cruise quit working unless I leave it as 5.7. Its weird.
    Jun 2021
    30
    Hey,
    Be careful when copy and pasting the tables. Make darn sure the temperature / RPM tables are the same. For some dumb reason mine starts at -49f and the hellcat was something like -10f to start the graph. I have bumped up the Stoich to 0.0785 now and wow what a difference.
    Mar 2023
    14
    Hey I will look at that shortly if I change stoich do I have to adjust injector pw calculations as well?
    Jun 2021
    30
    current tune as of today. make sure temperatures on the charts are the same
    Nov 2019
    227
    In order to receive more useful replies/help its best to post up an accompanying datalog (with a wideband o2 trace) with your tunes.
