Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: Redline LED's?
    Nov 2022
    LOS ANGELES
    38
    Quote Originally Posted by Only6NoTricks View Post
    I've already paid for the User Defined Parameters. I think my end goal is to be able to sufficiently make a DP tune, which was the main basis of getting the PCMflash software/hardware and the openport as well. I have a very long way to go though haha. The base offset makes a lot of sense as well. I've been using the winOLS demo for about a week to dig into a few random bins, and overall just learn how things are laid out, making changes, etc.
    Do you have any other tips for someone who is super new to the hex/winols mappack based side? Thanks for all the help, I'd send you a beer if I could
    If you have already paid for the User Defined Parameters, you can use this Xdf to modify the cluster speeds, Im not going to spoon feed you but this is a start to add extra parameters to.
    Tuner Only6NoTricks's Avatar
    Sep 2022
    Washington, USA
    64
    I appreciate you Drill! I respect your work on this platform.
    Edit: The base offset was a character off, here is the updated one.
    2013 audi A8 cluster updated.xdf
    2013 Audi A8L 3.0T WIP
    May 2014
    USA
    455
    My direct knowledge is only simos18 specific, but if you buy a winols mappack/OLS file you can then manually create the XDF from that info...the file will have many maps defined with all detailed defined. This is probably what you're looking at most realistically to add a few maps here and there and not too much $ or time invested. Places like nefmoto are probably a good place to start looking to buy mappack/OLS file or similar. WinOLS has an export to XDF feature but you need paid WinOLS + XDF feature....at that point you'd probably just be editing files in OLS anyways.
    Sep 2022
    Washington, USA
    64
    A friend of mine does have winOLS, so I could utilize that. Time isn?t too much of an issue but money on the other hand? Lol
    May 2014
    USA
    455
    Free version of WinOLS will let you open OLS files and do what I described above. Free version you can't save edited bin files is the big limiting factor.
  6. #26
    Sep 2022
    Washington, USA
    64
    Quote Originally Posted by aaronc7 View Post
    I?ll probably do most of the editing on winols, then every so often utilize his subscription. Thanks for all the help!
  7. #27
    Sep 2022
    Washington, USA
    64
    @TheDrill as promised: https://drive.google.com/file/d/1c1k...usp=drive_link
    Looking at it a bit further, it appears that my 4H bin would be the same as the 4G bin if im not mistaken...
  8. #28
    Nov 2022
    LOS ANGELES
    38
    Bin and gone..
    Thanks for that , I was pretty sure it was the same as my 4G once I discovered the cluster address's were the same.
    Your 4G bin lines up perfectly with my XDF, with a few differences here and there on the torque maps ect.
  9. #29
    Sep 2022
    Washington, USA
    64
    Thats awesome. Are you on revision 0005 too?
  10. #30
    Nov 2022
    LOS ANGELES
    38
    When I got the car it was on revision 0007 and I updated to the latest revision of 0010.
  11. #31
    Sep 2022
    Washington, USA
    64
    Weird, 0005 is the highest version i can update to.
  12. #32
    Jul 2019
    Wilmington, MA, USA
    155
    Here's my file...
  13. #33
    Sep 2022
    Washington, USA
    64
    @Elaw here is 7k for youA6 tune 2.9 lil milder 7k leds.hpt
  14. #34
    Jul 2019
    Wilmington, MA, USA
    155
    Perfect... thanks so much!
  15. #35
    Sep 2022
    Washington, USA
    64
    Happy Holidays!
