Results 1 to 17 of 17
Thread: Focus RS 2,3l Ecoboost Max Power
    Feb 2023
    10
    Hello, my name is Torsten and I'm from Germany, I've already bought an Mpvi3 and would like to use it to tune my Focus RS. I would also like to install the Precision turbocharger soon. Dynamometer is also available. Now I would like to hear some experiences about the maximum performance you have gotten out of the RS 3 with the software so far. Are 500ps possible or just 400ps? Sorry for the Bad English.
    380-400 with just software changes and no hardware on 99ron fuel
    Feb 2023
    10
    Thanks for your answer. My engine was completely removed and now comes the Precision turbocharger. Here in Germany we also have petrol with 102 octane.
    Feb 2023
    10
    Can anyone say more about this?
    What other info are you after? You won't see over 400ps with just software adjustments. Add in the usual hardware and you can see 430 however you are then entering forged engine territory
    Feb 2023
    10
    I wrote that I forged the engine and now the precision turbocharger is added. Is it possible to tune 500s with hp tuner?
    Yes, how you really need to understand the ECU logic to do it correctly and safely
    Feb 2023
    10
    I am aware of that.
    Feb 2023
    10
    I started today and I'm already at 440hp and 620Nm. But I can't get any further.
    Feb 2023
    10
    I reached my goal of 540 hp and 680 Nm.
    I think it's a shame that there's so little help here. But well I managed it without any help from you.
    Advanced Tuner skylinedan's Avatar
    Sep 2019
    Toledo Ohio
    262
    How do you know it made 540 HP ? You have it on a dyno, or is this a best guess based off your torque readings you got data logging it ? Getting any kind of help on here is hit n miss, all depends on the question. Sometimes your better off just reading the threads that pertain to what ever your issue is, and you'll find your answer.
    Feb 2023
    10
    I have a Dyno.
    May 2021
    20
    Quote Originally Posted by Thorsten View Post
    I have a Dyno.
    I have a 2017 focus RS
    Fully build
    2.3L close deck
    Pistons - rods
    Intercooler
    Precision turbo
    1700cc injectors
    I got the basics and now making 313hp and 298 Torque to the wheels on my Mustang dyno.
    22psi 2.58 load
    I need help Understanding the ignition timing tables.
    I advanced timing on the borderline mapping tables used on WOT from -6 -10 -12 to 1 to 3 degrees and I lose power. Same boost I?m not hitting limits.
    Any help or advice will be greatly appreciated
    Dec 2015
    Miami,Fl.
    293
    Quote Originally Posted by alsdriftshop View Post
    Fully build
    2.3L close deck
    Pistons - rods
    Intercooler
    Precision turbo
    1700cc injectors
    22psi 2.58 load
    Post tune and log if you can.
    2023 Ford Maverick 2.0T AWD
    May 2021
    20
    Quote Originally Posted by HeavyChevy305 View Post
    FOCUS RS TURBO. 4BAR MAP REV saturday.hpt2017 FORD FOCUS RS NEW TURBO 309hp 302torque saturday.hpl
    I understand the ecu gets the lowest values for everything. ignition timing and torque but why If I edit my borderline mapping tables to 3-5 degree advance it uses pressure cylinder values?
    am I understanding ignition timing wrong on this torque command ecu?
    Thank you
    here is the map and logs
    May 2021
    20
    I have a 2017 RS , build for 700hp, injectors, intercooler, precision turbo full exhaust.
    I?m tuning it on a Mustang AWD dyno and I can not get it to pass 300 hp to the wheels.
    Any idea? Any help
    Would be so greatly appreciated.
    Here is my post but I can?t get anyone else to help.
    https://forum.hptuners.com/showthrea...-2-3L&p=797899
    May 2021
    20
    My apologies I thought I had uploaded the logs and map
