Thread: proportional p/n idle spark control---- where is this?
    Mar 2023
    4
    hello all, im new to using this software. 2019 charger 6.4L. im looking to add some chop to my cam by changing spark timing. under idle controls isnt there supposed to be a airflow section to change idle spark porpotionals in p/n?. i only have general and rpm. has this setting been moved?. thank you.
    Edit- no need to reply, I found it. editor was on basic mode. Still much to learn
    Jan 2022
    914
    if it ain't fast chrome it
    [email protected]
    don tanklage
    how much or what numbers you use to make a chop chop idle ?
    thanks
    Mar 2023
    4
    Proportional spark p/n and d/r In the airflow tab on idle. You have to go to advanced settings to see the airflow tab. I took the base values and timed2 for a steady spark change. Lopes smooth.
