Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: Gen 4 e38 dfco tuning
  1. #21
    Sep 2021
    495
    It is fine to leave it disabled.
  2. #22
    Advanced Tuner morepowerjoe's Avatar
    Sep 2021
    Austin
    292
    Quote Originally Posted by 04silverado6.0 View Post
    Thank you sir.
    L99 A6 - DSS FX Forged Piston's, Eagle ESP L19 Rods, ARP Head and Main Studs, LS9 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnion Upgrade, TSP Chrome Molly Pushrods, BTR .660 Valve Springs, GM Hollow Intake Valves, Melling 10355HV Oil Pump, IR EGM-205 Oil Pan Baffle, CAI Intake, Fast LSXR Intake Manifold, Nick Williams 103 TB, ZL1 Pump, TSP 1 7/8" Longtubes with 3" TSP Exhaust, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter
  3. #23
    Mar 2022
    Florida
    134
    I run with DFCO off and open loop. Haven?t been having any problems and I?m very happy with the tune. Also I don?t allow my TCC to engage at all in any gear. I like the feeling of the simplicity of it. Very stable.
    2017 Silverado 3500HD WT 6.0 flex fuel 6L90 6800lbs E78 T43
    --- What am I doing??? Why did I do that??? ---
  4. #24
    Nov 2006
    2,861
    Quote Originally Posted by morepowerjoe View Post
    Sorry ahead of time for the newbie question but I have to ask. Are you guys saying that you can run with the dfco disabled all the time if you want to? Because I disable it every time I tune my maf with my wideband. But I think I noticed the other night when I was out scanning with it disabled I was hearing a lot of pops out of the exhaust when I let off of the gas at high speeds. Is this normal? Thanks guys.
    Typically means there is not enough timing in decel.
    Tuner at PCMofnc.com
  5. #25
    You can just leave everything on, and use proper filters to log OL and CL at the same time, makes things way easier.
    Also with DEFCO disabled you pretty much get no engine breaking. But to each his own.
    Search for GMVE in this subforum for more info. You can also use that thread as a guideline for MAF or VVE only tuning. Plenty of info in there.
  6. #26
    Sep 2021
    Austin
    292
    Quote Originally Posted by mememe123 View Post
    I'm glad you told me about the engine braking because I think I'd miss that.
  7. #27
    Mar 2022
    Florida
    134
    You can tune the deceleration areas in MAF and VVE tables to give you the amount of engine braking you want if you choose to turn off DFCO. I?ve been working with it and now have it how I like, not as much engine braking as before for me and not as lean as with DFCO on.
  8. #28
    Nov 2006
    2,861
    You can still have great engine braking without DFCO. If the engine isn't braking either running airflow is too high or there is too much timing in decel.
  9. #29
    Sep 2021
    Austin
    292
    Sorry another newbie question. Where do you tune timing for deceleration?
  10. #30
    Tuning Addict
    Jan 2015
    6,855
    dfco entry spark and exit spark for when it's in dfco and the very highest row of the main spark tables helps with transitioning...
    ~Greg Huggins~
  11. #31
    Sep 2021
    Austin
    292
    Thank you sir.
  12. #32
    Nov 2006
    2,861
    Idle base spark tables.
  13. #33
    Sep 2021
    Austin
    292
    It's hard to even know where to start when all you guys say something different. I was assuming that the lower the timing in the entry spark and exit spark tables the more pops and the higher the timing the less. But now I'm not sure since Alvin said it's in the idle base spark tables.
