Results 1 to 10 of 10
Thread: Fully Built Big Turbo & Cammed 2018 Ford Focus RS 2.3L
    Oct 2019
    CT
    34
    hello, I primarily do not tune ford but if I do its a mustang so this is new to me. Im having trouble getting this car to run right. if anyone is willing to lend a hand please let me know! Thank you!
    mod list: stroked to 2.5L
    2618 pistons
    2.5L H Tuff Rods
    85Lb valve springs
    piper cams B285
    balance shaft delete
    Garrett GTX3584RS Gen 2 Turbo
    Twin Tial MVS wastegates
    Tial sport BOV
    3in downpipe w/ highflow cat
    3.5IN intake W/ 4IN air filter
    Turbo bypass valve control solenoid delete
    Step colder sprak plugs
    Jan 2015
    565
    Post tune and data logs as well as specific issues that you are having
    Advanced Tuner skylinedan's Avatar
    Sep 2019
    Toledo Ohio
    243
    Also be helpful to know what if anything was done to the fuel system, a GTX 3584 is pretty big for a stock fuel system.
    Oct 2019
    CT
    34
    i dont have a tune made as i dont really know where to begin.
    the issue i am having though is rough idle. Commanding .65-.80 lambda at idle, breaking up during light acceleration.
    Oct 2019
    CT
    34
    its stock fuel system with port injection added with its own controller for the injectors. but this is currently not plugged in until i can get it to idle and cruise properly
    Oct 2019
    CT
    34
    stock1.hptwtf is going on.hpltuned.hpt
    here is the stock file
    a log
    and a "tuned" file of me just messing with some settings.
    also this is the Mountune Focus RS
    Oct 2019
    CT
    34
    any idea?
    Jun 2019
    Wisconsin
    300
    Just a guess is that the cam and high displacement is probably throwing off idle VE calculations, will probably have to find the mapped point that idle uses and use the speed density calculator to add some fuel in the right areas.
    Sep 2019
    Toledo Ohio
    243
    Needs the engine size changed to start with, and that cam is gonna be another issue getting dialed in. Also, are the injectors stock ? If not, then those are gonna need attention too. I'll get a look at your files later, I need to get to work, but I'll see what I can find when I get a minute.
    Sep 2019
    Toledo Ohio
    243
    I took a look at the tune you posted and the data log. You got some weird stuff going on that makes no sense, I,m not seeing any boost, and your air flow is way off for a charger that size. I'll have to look at it more, but I've got other stuff gong on, so it might be a while.
