Results 1 to 20 of 21
Thread: No prep tune
    Feb 2019
    Owensboro, KY
    266
    No prep tune
    Looking for suggestions and the best area to pull power to make these heavy ass cars get outta the hole and beat 60ft I can on a no prep track and on radials.
    Found 37844 labeled toqure limit per gear vs mph.... would changing these values down cause any issues??
    Also was told to use the launch under spark and advance and give that negative numbers to pull timing there? But I'm not sure how that area works. Launch control?? Foot brake??
    I don't use the launch control and haven't messed with that in the tune to find how it works. Any help?
    6.4 Whipple Diamond pistons Manley rods, Demon Plus Cam
    Aug 2017
    Quakertown PA
    481
    What year are you working with? I forget, it’s older , 2010?2012?
    G3 Hemi Videos
    Aug 2017
    Quakertown PA
    481
    Quote Originally Posted by FstdodgeKY View Post
    Found 37844 labeled torque limit per gear vs mph.... would changing these values down cause any issues?? YES
    The thing about the launch tables is once the ETC goes in to WOT they are ignored.
    When the company I retired from bought it's 2015 Drag Pak car, when the "pro- Tuner" guy came to help us set it up, he showed us how to use the table, ... This was before Holley came out with the "DP terminator system. the the thing that took the longest to get right was the transition, between PT/WOT and Cold Launch, in the end we left the pedal WOT table high, some where in the 3.1-3.2 V to keep from sending the car in to WOT off the line. Both Temp and RPM axis we heavily changed.
    Now I have two Dirt guys with NGC systems that I use Cold launch to help them off the line, and when we ran the 460CI G3 in my nephews truck we used it to help settle it down for the 1st 60 ft.
    G3 Hemi Videos
    Jan 2022
    910
    not sure of your power level but if i had to run stock pcm i would use a bias ply for no prep
    what year? what trans? what converter?
    [email protected]
    don tanklage
    Feb 2019
    Owensboro, KY
    266
    15 charger scat
    8hp90 stock converter
    Whipple 18#
    100 shot nitrous
    Daily driver everyday.
    Jan 2022
    910
    Never shoulda put a 90 in it. Not for that application.
    A glide (with the right convertor obviously) and bias ply 10x more forgiving
    Drag radial needs to dead hook and that is not gonna happen on no prep
    [email protected]
    don tanklage
    Feb 2019
    Owensboro, KY
    266
    I wanted to do a th400 but got talked outta that due to daily driving the car. Burnt up 3 built 70 before I cut my losses there. Can't run bias ply at no prep due to rules
    Feb 2019
    Owensboro, KY
    266
    Car hooks good on prep no issues there. Cut 1.30-1.40 60ft. Haven't been able to spray it yet due to still stock axels.
    Feb 2019
    Owensboro, KY
    266
    Can someone explain how the cold launch is activated? Does it aways use this when the car takes off? Like from a stop vs when actually launching at the track? Or only when using launch control??
    Mar 2021
    Pompano Beach FL
    267
    We have been testing this and it works well,
    https://www.americanmuscleperformanc...AX_p_2371.html
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    Aug 2017
    Quakertown PA
    481
    Quote Originally Posted by N2speed View Post
    Works great, but for the price it should
    G3 Hemi Videos
    Aug 2017
    Quakertown PA
    481
    Cold launch, and tc, are separate,
    Cold launch is activated by temp and deactivated by mph/wot
    When I use it, it’s a tune specifically written for track day,
    G3 Hemi Videos
    Mar 2006
    Detroit
    1,033
    I'd be willing to bet that the 8HP70 would have been just fine if your part throttle torque model was right. You probably damaged it "driving around nice" and only finished it off at WOT. Just sayin...
    Anyhoo, You really want to soften the driver request torques at low vehicle speed to help launch on slick surfaces. You have ~16:1 torque multiplication available through the gears and convertor, which is way more wheel torque than you can plant. Soften the input request and watch it hook.
    Feb 2016
    431
    Leave in 2nd - all the cool kids are doing it.
    Jan 2022
    910
    Cold launch just offsets catalyst warm-up.
    right? i mean there is already a tip in table (and who knows how many others that we do not know about?) so why this additional table? i think it is there to offset something as well
    would love to see the purple ram 'track day' tune for that table. mines done at 2500 rpm. how does he figure wot deactivates it? if it did how could it be used for 'track day'?
    track day is for my 1199R : )
    Jan 2022
    910
    for 5 bills should be able to write a map for throttle application
    *contempt prior to investigation - what all can you make it do using just the two knobs?
    Jan 2022
    910
    funny how it says 'used to modify timing during cold start take offs' but the low rpm timing it throws at it is almost identical all the way up to 230 ect
    Oct 2021
    Allentown PA
    363
    I asked Ric(Purple Ram) to set up a launch deal for this truck, we went the opposite direction, Needed More timing at 1800ish RPMs, couldn't get the PT table dialed in to get our results and didn't want 22* at that spot while driving .... , that 22* of timing has to be coming from some where,. Sure is NOT mbt table, sure is NOT pt table, and it's sure as hell not on the WOT table.
    Just saying.....that 22* degrees of Timing wasn't there when the Cold Launch table read all 0's
    (Disable MPH is set at 12MPH)
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
    Jan 2022
    910
    attach that log instead of just a still
    *added a log n a still. Blipped it in low at a minute 4
    Feb 2019
    Owensboro, KY
    266
    Thanks guys ill look into the driver demand tables for better launch.
