Results 1 to 18 of 18
Thread: Anyone have a stock ?18+ 5.0 flex fuel engine file I can use to convert over 3.5 EB?
    I?ve got a 2020 f-150 w/ 3.5 ecoboost. I?m going to be enabling the flex fuel logic to enable ethanol based fuels but I have to blend some of my tables and adjust some parameters that aren?t defined from the non-flex fuel file. If anyone has a stock file they can share, it would be greatly appreciated!
    Aug 2022
    8
    Post your stock file
    Aug 2022
    8
    Here Try this stock 2018 F150 3.5 10 speed auto 4x4 tune with 3.55 gears - Flex Fuel Tune.hptstock 2018 F150 3.5 10 speed auto 4x4 tune with 3.55 gears - Flex Fuel Tune.hpt. Just Copy the FF settings this is based off the stock file (stock 2018 F150 3.5 10 speed auto 4x4 tune with 3.55 gears) from the repository.
    Aug 2022
    8
    a few changes to help boost the E85Attachment 130392
    Here is my stock tune:Stock Tune 2020 F-150.hpt
    Thanks! That’s was quick; I appreciate it. I’m trying to start around E30-E40 and see how my fuel system holds up.
    * looking at your Files, it appears that one is a dedicated E:30 tune were the other one is just a flex fuel tune…? Significant gains with the dedicated versus flex?
    Aug 2022
    8
    They are both flex fuel tunes that can run up to E85 or any combination in-between E30 upto E85. The First tune is your stock tune plus flex fuel. The Second tune is stock plus (I know you might be tuning your own vehicle based on how you would like it to be) so I just added the second in case you wanted a temple to compare your own tune to and see if you want to raise or remove some limits in the stock calibration so you can get a little more performance.
    I got everything switched over except for my bias corrections for flex fuel on the O2 sensors and cats. I noticed yours were zero’ed out on your tables. I was going to make them proportional to another flex vs gas table. Any chance you have a stock file (maybe 5.0) that compares the gas vs flex bias charts..? Thanks in advance if you or anyone does.
    Aug 2022
    8
    You need to copy over your stock value from your stock file into your o2 bias and cat from your stock file over to both the flex fuel for those values as well. The Flex Fuel values that are zero'd out need to be the same for both gas and flex fuel for your o2 and cat so they are identical.
    The only thing I’m confused about is that on a 5.0 flex fuel vehicle the bias are different between standard fuel and flex fuel. Wouldn’t I need to have those different as well on mine?
    Aug 2022
    8
    Quote Originally Posted by Perna00 View Post
    no it will be the same
    Ok, easy enough
    May 2023
    1
    I am a noob to HP Tuners and looking to create a flex fuel tune for my 2013 F150 EB for E30. My bluetooth Ethanol Sensor shows me running E30 +/-5% while keeping an eye on other parameters in Torque Pro.
    I have a tune from a 2015 F150 5.0 FFV to use for the Flex Fuel parameters but cannot figure out how to copy over the FFV tables manually or using the template I made from the parameter under Engine -> Fuel -> Flex Fuel.
    Any help is greatly appreciated.
    Oct 2023
    3
    Does anybody have a 2018+ 5.0 flex fuel engine file? I can use to convert my 2018 Mustang GT premium auto10 speed. please and thank you
    Jun 2020
    815
    Just grab a stock gen3 f-150 file.
    Oct 2023
    3
    Trying to make my 18 gt run on a flex fuel tune
    Quote Originally Posted by engineermike View Post
    Yes sir thank you very much
    May 2019
    17
    i have a stock 2019 f150 5.0 flex tune
    I appreciate the replies on this old thread. I ended up getting a file a while ago and have had success with the conversion. Thanks for the follow ups.
