I am helping a buddy get his cam swap started. 2014 Camaro ss, stage 2 gpi cam, kooks headers and valvetrain for the cam. I have started on the file already but probably wont have the car together until at least a week. I plan to start with the maf as it was already dialed in for the stock cam via wideband. Can someone help me get a rough vve table started and check my file over? Also would it be a bad idea to raise the fuel pump pressure to 58psi across the board instead of the factory low pressure high flow strategy? Ive attached the last file to run the car on stock cam and the startup file for the cam swap. We also had trouble with the headers causing the o2 mv to switch slow at idle even after various changes to the delay tables i will need help with that as well.
