Results 1 to 6 of 6
Thread: 6R60 Shift Patterns
    Mar 2022
    17
    6R60 Shift Patterns
    Hello. In Ford Explorer 2006 TCM I can see 32 shift patterns. Witch one is used by the TCM ?
    Apr 2023
    11
    Hey, Im in the same boat on my 07 expedition with 6r. Did you figure out which shift schedule to use? I know your post is a few months old.
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    488
    Should/maybe be a PID in the scanner you can see which map it uses.
    Apr 2023
    11
    Quote Originally Posted by projectlnf View Post
    OK, Thanks, ill look that direction.
    Mar 2022
    17
    I can t find it. ssks72107 did you find it ?
    Nov 2020
    35
    I've found that my Snap on SOLUS has a shift id pid that correlates to the shift tables. The pcm uses many of the shift tables for different operating conditions. Just make a shift schedule and copy/ paste all maps except the maps for the manual shifter positionsAlso my 08 Explorer table 3 is man1, 8 is man3,i forget what man2 is but it's pretty obvious when looking at them. I finally was able to make my man3 position run on one shift map. I gave it gears 1-5 with a performance/ towing shift schedule. Figured out how to make the converter lock up accordingly too. I'll post about it if anyone is interested. Lmk
