Results 1 to 10 of 10
Thread: Throttle torque source stall
    Aug 2022
    16
    I've got a 2020 392 with a whipple, cam, 105mm tb. I've been fighting this issue with this tune for days now. When I got WOT it closes the throttle then opens back up at about 5k rpm. I can post logs and files just wasn't sure how to add then. Throttle torque source, slow path and fast path always switch to stall. I know there must be a torque or airflow limit I'm missing.
    Jan 2022
    916
    There is a problem with your ECT sending unit
    The system thinks the motor is still stone cold like you just started it on a 59 degree morning
    It doesn’t know it’s been warmed up
    Take it thats a hub dyno?
    Aug 2022
    16
    No I'm on the street. It shows correct coolant temp on the log and the dash.
    Aug 2022
    16
    Quote Originally Posted by spoolboy View Post
    Post your file and a log.
    done
    Dec 2021
    Spain
    51
    Quote Originally Posted by Stultzd View Post
    I have a cam lock. Do I need to turn vvt off in the tune? That's what I did
    Sorry guys I was replying to the wrong discussion. Sorry for creating confusion here.
    Aug 2022
    16
    Quote Originally Posted by LilSick View Post
    deleting a post is almost as easy as warming up your motor : )
    The engine is deff warm. I drive around for hours and it still does it. I don't even do pulls until the engine and trans are at 170 at least
    Aug 2022
    16
    And I logged the engine comment temp thru the engine and trans channels and both are at 185 or higher when I'm doing the WOT pulls
