Results 1 to 20 of 21
Thread: VCM Scanner randomly disconnects while logging
    The scanner will randomly stop logging. Sometimes after 12 minutes, sometimes after 2. I have disabled the "turn off usb power to save power blah blah blah" on all the USB ports. The cable is damn-near brand new as it's the one that came with my MPVI3. It's not wiggling around, either.
    Yes, I could take another laptop and see if it starts happening on that, but I'm not there yet.
    • 2001 C5 Corvette (625rwhp - Procharger, LS6 heads, Torquer V2 cam)
    • 1991 Volvo 940 - 2JZGTE (600rwhp - PT6466, HKS 272 cams)
    May 2023
    Quote Originally Posted by phuz View Post
    Did you ever resolve the issue? I?m running into the same issue after updating my MPVI3
    No I haven't yet. The other day it ran fine for the entire 23 minute drive and then next time it stopped after 1.5 minutes.
    It's damn frustrating.
    Feb 2012
    16
    I'm having connection issues also now that I have a 3. My 2+ was fine.
    2,861
    This is usually my sign to throw away the usb cable and get another.
    It usually fixes it.
    Tuner at PCMofnc.com
    Feb 2012
    16
    I have tried that.
    2,861
    I also routinely take cotton swabs like a qtip but for industrial use with alcohol and clean my USB ports and rebend the little tangs that hold the connection tight.
    Not a bad thing to do, but other devices have no issue staying connected.
    It's the new cable that came with the MPVI3.
    Advanced Tuner Josue Galban's Avatar
    Jan 2023
    Venezuela
    205
    Maybe you should try another cable, this has happened to me very often and I have had to vote for many cables, find a normal one that does not require a specific voltage
    Jan 2022
    913
    i got a extension so i could move the interface to a location where the hpt cable could be secured and ran under the floor mat
    Same, although mine is secured on the passenger-side area. Still doesn't address the issue.
    Sep 2023
    15
    same problem with mpvi3 and win7 x86/
    and more: made one log with list of parameters and after few days vcm scanner shows than some of them are not supported and cant be logged.
    Quote Originally Posted by Lammer View Post
    For the second issue, go to Vehicle -> Repoll for Supported Parameters
    Sep 2023
    15
    After I made this amount of parameters in the list became less than before when I could record it. Now I cant find and add it using keyword.
    very strange. Ill try again later
    Dec 2022
    Austin, TX
    18
    Anyone find a solution. Im having this same issue. Tried diff cables and diff laptops.
    I read some older posts and they were talking about logging too many channels and maybe too many histograms. I have a ton of both so I might go remove some that I dont need and see if that helps.
    I removed a few channels and decreased the polling interval for stuff like Idle Desired RPM, PRNDL status, Fans, ECT & Trans Temp. Well see if that helps.
    Quote Originally Posted by joshlarsen View Post
    No, and the only response from HPTuners has been to "replace with a quality cable" so I'm guessing they don't have an answer for this. I don't think it's a matter of number of channels or histograms because I've been using the default layout and had the issue when I was only logging 10 channels.
    Dec 2022
    Austin, TX
    18
    I'm pretty sure its the cable. I cut back the channels I was logging and histograms and still had a couple lock ups. The other day I was messing with truck wiring and just set the ODB2 port connected to my MPVI3 into the glove box from under the dash and didnt experience any issues logging until one day my daughter opened the glove box and boom logging stopped for everything except my wideband which is connected to computer via serial. I have not had the issue one time since so im pretty sure its all in the USB C connection on my MPVI3 that was causing the issue.
    I bought a brand new cable, and the cable is completely free and does not move while logging. This is a regular USB-A to USB-C cable. I am going to try another laptop with USB-C / USB-C and see if there's any difference.
    There is no rhyme or reason when it stops.
    5BA8
    3,456
    Try getting rid of a bunch of your useless pids. GEN3s don't like logging a whole bunch of pids.
    You have your long term fuel trims turned off. No use logging them. Your car doesn't have an IAC. No use logging it. There's a bunch more you could do without.
    email=[email protected]
    Quote Originally Posted by HerbieJ View Post
    Per the suggestion, I removed about 10 channels that I wasn't actively using and I have successfully had 2 back-to-back 10-minute logs without disconnecting. Not ready to call it resolved yet, but seems much better.
