At first I thought this might be a injector tip temp thing, but the values from 100-135 ITT are all 0s so not that..
Regulator/fuel pressure not touched between pulls. Just a warmed up pull, then another 15 minutes after no change
Factory Stock 97 SS M6 13.51 @ 104.3 mph
Stock Longblock LS1 w/ 233/238 P.S.I. Cam
10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
'99 TA trunk mounted 76mm 6 Liter
9.0s in '09 @ 153 MPH
Turbo 5.3 Volvo 740 Wagon
32psi and still winding out 5th on the highway somewhere
As long as you didn't shut if off between pulls, log barometric - guarantee it changed. You have to do the enhanced OS to work around this or only do your fuel adjustments after getting into boost.
~Greg Huggins~
