Results 1 to 4 of 4
Thread: How much timing are you using for high octane on a LT4?
    Apr 2023
    8
    How much timing are you using for high octane table on a LT4 during boost?
    I guess most common is 93 in US and 98 in EU.
    Jul 2021
    234
    on pump 93 probably not more than 20-22 up top.
    May 2003
    South FL
    1,381
    Depends on humidity and weather and if you have mods. Stock tuning, the ECU commands between 22-23.5 of peak timing on pump 93. It starts out much lower when going WOT in the lower RPM range.
    [email protected]
    Owner/GM Calibrator
    Tuning Addict
    Jan 2015
    6,844
    Quote Originally Posted by TriPinTaZ View Post
    I screwed up on a humidity table Started out with stock settings and it added 3 degrees of timing to a slightly detuned tune that I was using to dial fueling back in after some more mods were made on a 22 ZL. Showed me roughly where this particular gentleman's peak timing was on the stock knock settings - right at 17 degrees ;/ I'm still letting it add some timing at full humidity levels (like 1 degree) - just not stock settings - teaches me
    ~Greg Huggins~
