Results 1 to 14 of 14
Thread: 2013 F150 5.0 tuning
    Jan 2020
    7
    Hey everyone, just picked up a mpvi3 for this thing. I want to adjust the torque management and shift rpm/speed for starters. Which set of parameters are to be adjusted for this? Thanks in advance
    Mar 2022
    Indiana
    2,981
    Open VCM Editor. Click OS. Apply RPM patch code modification.
    Jan 2020
    7
    Nothing seems to change the shift points for this thing. I set rpm limiter higher and even in manual, 6200 or so max
    Mar 2022
    Indiana
    2,981
    Changing WOT should have an effect.
    The others won't matter because the transmission is in Torque Based shifting schedule instead of by gear.
    Jan 2020
    7
    Which section would that be in? Because I've try numerous changes to this
    Mar 2022
    Indiana
    2,981
    This is from a 2013 F-150 5.0 file:
    You've tried changing it?
    Mar 2022
    Indiana
    2,981
    Ohhhh. Maybe you have to go to Airflow>Electronic Throttle> Pedal Pos WOT Start and End. Sorry didn't think of that. It's one of the first changes I make.
    Pedal movement is 0-512 counts.
    Start = 436
    End = 496
    Jan 2020
    7
    Wot shifts set to 6500, and pedal movement set, still no good. Maybe even worse. Shifts 56-5800
    Jan 2020
    7
    Figured it out, now hitting 7k on the shifts. Now to get them a little quicker and firmer. Also noticed the throttle not opening as fast as the pedal. And how can I get some of the torque management off?
    Mar 2018
    447
    Figured it out,
    Care to share what you figured out?
    Many of us have never seen a gen 1 truck
    Mar 2022
    Indiana
    2,981
    What was the fix?
    Get me a log with these settings. Let's see if a limiter is in effect.
    Jan 2020
    7
    Turned all rpm limiters to 7500. I believe the 1-2, 2-3....shift mph is what changes it. My laptop is at work so I'll load the log tomorrow
    Jan 2020
    7
    this work?
    Mar 2022
    Indiana
    2,981
    Yep no limiters active.
