updates / questions:
P0178 - Fuel Composition Sensor Low Freq (new one - i'm not a flex fuel truck and don't have the sensor)
*Validated replacement connector and pigtail splice, cut out solderstick splice, replaced with crimped, marine grade h/s splice and overlayed with h/s tubing. Ran through diagnostics up to hooking up AWG and stopped.
**Next steps: will need to trace wiring from FF sensor harness up to ECM.
***QUESTION: my truck was not a "FlexFuel" optioned vehicle and did not have the associated sensor. My truck is reporting 40% ethanol content currently (score!) which leads me to believe there are obvious wiring issue yet to be discovered (2x score). How did GM address sniffing alcohol content on cars that never had the sensors installed? Did the ECM monitor some other PID's and figure it out?
This is how it's set up in the tune - change to disabled and it'll get rid of that code. You also need to set the dtc to no error for the sensor although once it's set to not have one it shouldn't run the test. 40% is the default for an open circuit or sensor fault once activated in the calibration.
P0192 - Fuel Rail Pressure Sensor Circuit Low Volt (consistent code - have replaced the sensor, still throwing code, likely short)
*pulled blower to access sensor cleanly / completely, front probed sensor connector and ran continuitty and ohm check from end to end (X2 and X3 connectors) every thing rang out and displayed .3 to .4ohm. Seems like wiring is not the issue. Possible CanBus / 5v ref system issue?
**Next steps: run prelim checks on balance of other codes to see if any scales of magnitude / elimination can plow through some of these
Take a look at this youtube vid to make sure the correct connectors are hooked up. https://www.autocodes.com/p0192_2015...silverado.html
P0315 - Crank Position System Variation Not Learned (consistent code - cant clear until i can start the engine is my understanding)
*no action on this one - need truck running first
P0532 - AC refrig pressure sensor low volt (consistent code - replacing AC system shortly - no big deal)
P0621 - Generator L-terminal (consistent code - repairing connector once i receive it)
*spliced in new connector - issue resolved
P06A3 - 5V Ref 4 Circuit (new one - related to APP Sensor 1 and possibly TPS? inspected APP 1 connector and all looked ok but need to hook up and read the voltages on the pins)
P127C - Fuel Rail Pressure Sensor 2 low voltage (consistent code - related to 0192)
P06DA - Engine Oil Pressure control solenoid valve control circuit (consistent code - i believe a carry over code from VVT/DOD delete that needs to get turned off)
*double checked code - can be turned off, its a carry over from dod delete and is not applicable any more.
