Results 1 to 3 of 3
Thread: VVE Table Editor Grayed Out
    I just noticed that when I try to change cam angles in the VVE table editor, the task bar at the top that allows you to make changes (add, multiply, equals etc...) gets grayed out and doesn't allow you to make changes. Even after I change the cam angles back to zero for both, it still does not go back. I have to close the table editor and re open it to gain functionality and it's the same thing every time. Is this a glitch? I'm running VCM Editor 5.0.4. I'll post some screenshots.
    https://drive.google.com/file/d/18cZ...ew?usp=sharing
    https://drive.google.com/file/d/1yHD...ew?usp=sharing
    Can't edit any of the cam tables other than the base table (both cams at 0); to change the other tables you'll have to change the VVE coefficients directly.
    Not sure why you wouldn't be able to edit the base table without having to close the editor - maybe computer just needs a restart? My scanner acts funky and doesn't record properly the odd time, and a restart fixes it.
    Jan 2014
    SoCal
    1,578
    Is that the emissions version? Did you take the HPTuners "test" and get the software unlock code?
