Results 1 to 6 of 6
Thread: Rev Limiter Issue on Gen 2 Ecoboost 3.5
    Jul 2023
    1
    Hi All,
    I've been trying to figure out the limiting factor for the rev limiter on my 3.5 Ecoboost gen 2 mated to a manual gearbox. I was previously hitting a popcorn limit at around 3k rpm, but after raising the LSPI table values, it's now hitting another limiter around 3700 rpm or so. According to the serial data logs it says its at the "engine speed limit" even though I've placed it at around 6000 rpm. Is there something simple I'm overlooking?
    DMC_Ecoboost_Tune_4.hpt
    engine-speed-limit.hpl
    No expert here, but it looks like your in park with your foot to the floor. Somehow you need to tell the ecm that your in gear.
    Jan 2018
    5
    BUMP Having same issue with manual swap and 19 ECU Gen 2 EcoBoost any solution?!
    Mar 2019
    8
    turn the automatic from enabled to disabled for one, then set infer neutral to enabled.
    Jan 2018
    5
    Won?t run after doing that and throttle body flaps like ECU is bricked
    Aug 2024
    2
    any solution? I having the same problem.. my engine fire up well but wen I rev up... It cuts off at 4000 RPM (Ecoboost 3.5 2018 with MT Seq).
