What is the best fix for stripped coolant hole threads? My initial thought was helicoil but i got to thinking about the tang on the helicoil needing to be removed and also whether or not it will leak around the helicoil. Going to try to fix without having to drill the hole bigger, so, I'm looking at purchasing a thread chaser in hopes that it will help. Other than that, i'm all ears for a solution. What have you had success with in this type situation where this is a through hole? Thanks in advance.
