Results 1 to 6 of 6
Thread: 3rd Gen 78mm TB to TBSS Inteke 90mm TB
    Tuner Life is an Enigma's Avatar
    Jul 2022
    California, Where they suck the fun out of Life
    86
    I am working on my base tune for my swap project. Have a mild build 3gen 5.3 with 10.6.1 CR with new 2004 ZO6 cam. I am going to be running the 4th Gen TBSS intake with DBW 90 mm throttle body. I am using a 2004 GMC Yukon Base map. Did a segment swap ( same operating system ) with a 2004 ZO6 Corvette changed engine type to 5.3 change cylinder volume to the correct volume for the 5.3. now my question is in the idle tab under airflow. I already changed the ECT area scaler to match up to the 90 mm throttle body (0.0192) My question is is there anything else under the airflow tab or any other tab I need to change for this intake and throttle body to work correctly.
    7,883
    Corvette injectors or TBSS injectors? Or 2004 Yukon injectors? And which of the three most closely matches the fuel system type (returnless, referenced)?
    Jul 2022
    86
    I'm going to be running a returnless fuel system with 50lb injectors P/N 12613412 with the Cadillac CTS-V fuel filter works the same as the Corvette with the return on the filter. This will be a flex fuel tune. I would like to try mainly to stay on e85 but sometimes it's not available in a lot of places.
    Jul 2022
    86
    My poor man Z06 5.3.
    Parts list.
    5.3L L59 from 2003 GMC Yukon SLT.
    159K Miles on it when pulled.
    New GM Performance Camshaft from 2004 LS6 Corvette P/N 12565308.
    Gen 3 243 64cc Heads milled down to 62cc.
    DELPHI 12613412 50lb Ev6 injectors.
    Chevrolet Performance Head Gaskets -12575329 Compressed Thickness 0.052 in.
    Chevrolet performance valve springs P/N 19420455.
    Brian Tooley Racing Rocker Arm Trunnion Upgrade Kit BTRTK001NB.
    Gen IV Rods P/N 19209286.
    ARP 134-3609 Performance Series Cylinder Head Bolt Kit.
    ARP 134-6006 Connecting Rod Stud Kit.
    Current performance Motor mounts & Blazer 2WD transmission crossmember RCS10B-700 .
    GM 302-1 muscle oil pan
    GM PERFORMANCE Dipstick Tube P/N 12570787
    GM PERFORMANCE Dipstick P/N 12570788
    Holly Blackheart exhaust manifold P/N 7122 30 26 HKR.
    2006 C/N 6CPD C-Police Truck 4L60e transmission from a retired NYPD fleet Chevrolet Tahoe with TransGo shift kit HD-GM92 TMBX torque converter for now.
    Also with Sonnax heavy duty 3-4 clutch plate kit with 7 clutch pack I'm using Raybestos GPZ105 clutch set and upgraded to AC-Delco P/N (24241244) rear heavy duty 5 - pinion planetary and I order a Sonnax 77284-K front six pinion planetary it will change first and second gear ratio. First Gear Ratio: 2.84: 1, Second Gear Ratio: 1.55:1.
    Holly Blackhart AC evaporator side cover P/N 71223028HKR.
    Speedway motors 4130 chromoly steel Upper Control Arm P/N 91605012
    LS1 Camaro / GTO water pump with LS1 Camaro / GTO harmonic balancer. With modified alternator / power steering bracket to line up with GTO harmonic balancer and water pump.
    Melling M295HV High Volume Oil Pump with 60 PSI spring.
    Melling BD417-DBRKT - Melling Timing Chain Dampener Bracket
    Dirty Dingo DD-LS-AC-LM-CMV lower passenger side mount A/C bracket kit with Sanden SD7B10 mini compressor.
    Quantum-340lph-direct-drop-in-performance-fuel-pump-assembly for 2dr 2wd Blazer P/N QFS-A822HV.
    AEM (30-4110) UEGO Air/Fuel Ratio Gauge
    Summit Racing SUM-326943780-2F Forged Pistons + 2cc dome Bore 3.780.
    My compression will be 10.6.1 CR.
    Custom engine cover for TBSS intake manifold.
    Jul 2022
    86
    Anyone have any suggestions of anything I might have missed? I know this question has been asked a trillion times a trillion different ways but all the searches I did came up with very little. it would be nice if one of the technical guys that knows what they're doing would put all the information into one thread on how the do the TBSS intake swap and the settings that you would need to change in the tune for the 3-Gen platform and make it a sticky at the top of the page. Any help would be appreciated.
    Thank you.
    This is what I changed so far on the tune file.
    I did a engine segment swap from a 2004 Corvette ZO6.
    I change engine type to 5.3.
    I changed cylinder volume two 0.066594.
    I change desired throttle area in electronic throttle from Corvette pedal to match the 04 Chevy Tahoe / Yukon pedal settings.
    I also changed fuel/ temperature control/ enrichment rate vs temp to match the 04 Yukon since I'm going to be using the catalystic from the 04 Yukon.
    And I copied and pasted Target idle speed vs coolant temp filled in all boxes. The Corvette does not have P/N AC on and off idle filled in like the Yukon so I copied the two upper and pasted into the two lower since I'm going have AC.
    Under idle under airflow I did change the ECT. Area scaler to match for the 90 mm DBW (0.0192)
    And I copied all the fuel settings for the flex fuel from the 2004 Yukon.
    And since this is going in a 2004 2wd S10 Blazer I did a segment swap for the P59 fuel system/ P59 system / P59 speedmeter. That way my speedometer gas gauge and tachometer all work correctly.
    Jul 2022
    86
    Almost missed this one. The tac module settings for idle. The '04 Yukon/ Tahoe tach module has different settings from the '04 Corvette tac module. And it says no little bottom box. If settings are incorrect, it can permanently destroy the PCM.
    04 Corvette
