Results 1 to 10 of 10
Thread: Idle timing erratic (1999 JTEC)
    Jul 2021
    44
    I've been messing with this for a while. It was dyno tuned by a shop in Kennesaw Ga. The tune wasn't quite correct, so instead of keep paying them hourly to keep messing with it, I bought a MPVI2 to try my hand at tuning it. The JTEC platform is really basic as compared to other platforms. I've had some help from a few guys here on the forum (Thanks [email protected] and hexdummy for sharing some knowledge). Engine is a 5.9, 9.6:1, edelbrock heads, 218/226 @.050 525/525 lift, 112 installed @ 108. Stock intake, stock injectors, dual 2.5 exhaust, nothing crazy.
    Fuel trims look dialed in. I'm not real sure about the main timing table the tuner set up. It looks really conservative. I may mess with that some later on. One of the things I've noticed is my idle timing on the VCM scanner is all over the place. Since the computer controls timing, what could be causing this? The IAC fluctuates also. Vacuum at idle is 14hg and is steady. Compression test on all cylinders is 175psi. this is a new engine i built. Cam was installed with a degree wheel so i know its installed correctly.
    idle_ac_run.hpl
    Jul 2021
    44
    Jul 2012
    Colorado Springs, CO
    42
    Did you ever figure anything out on this? Mine does weird stuff too and I don't understand why.
    Did you perform an idle sync?
    Aug 2006
    5BA8
    3,458
    Both behaviors are perfectly normal. It uses both the IAC and timing to control idle speed. Neither are supposed to be steady @ idle.
    Idle synch has nothing to do with it.
    EFI specialist
    email=[email protected]
    I got a hotter 5.9 that his and mine idles fine with a slight lope, it doesn't hunt for a steady idle. If it's hunting for an idle something with that small cam, something isn't set up right.
    Aug 2006
    5BA8
    3,458
    Quote Originally Posted by EvilR/T View Post
    I got a hotter 5.9 that his and mine idles fine with a slight lope, it doesn't hunt for a steady idle. If it's hunting foe an idle something with that small cam, something isn't set up right.
    It's not hunting for an idle. The behavior of both the IAC and the timing are completely normal.
    This is the table for your idle spark. "Proportional gain for idle spark based on RPM error". All EFI systems use spark to control idle speed. The IAC is supposed to move constantly also.
    EFI specialist
    Totally misread that, sorry. Yes, all that in mine is moving around too, PCM is consistently adjusting.
    Jul 2021
    44
    This tuning stuff is all new to me, and there?s not much info for the JTEC platform. Can you explain what these number mean in this table?
    Jul 2021
    44
    I thought the same thing, that?s there something wrong with the engine. I did a compression check, all cylinders were 175. I did a leak down check and all cylinders were near zero. I?ve about had it with this engine. I?m about to pull it out and tear it down. Hell I might just replace it with a Hemi and a stand alone EFI system like a Holley sniper.
