Results 1 to 5 of 5
Thread: Dakota rt jtec+ speedo calibration not available????
    Tuner in Training jbliss15's Avatar
    Feb 2020
    38
    Only thing that shows up for speedo calibration is final drive ratio max and min what does that do??
    98 ls1
    Feb 2020
    38
    if the out of the box device programmers can do it there must be a way
    98 ls1
    Feb 2020
    38
    does anyone know if adjustment the gear ratios for the transmission will effect the speedo output?????
    theoretically i could change the gear ratios in the trans to compensate for the tire size difference if it was part of the calculation
    98 ls1
    Jan 2022
    801
    maybe if you start a couple more threads on it...
    Feb 2020
    38
    I only started one. This forum is dead
    98 ls1
