Results 1 to 6 of 6
Thread: Dakota rt jtec+ speedo calibration not available????
    Only thing that shows up for speedo calibration is final drive ratio max and min what does that do??
    2000 Dakota R/T
    gt45
    42lb
    honda map
    10psi
    if the out of the box device programmers can do it there must be a way
    2000 Dakota R/T
    gt45
    42lb
    honda map
    10psi
    does anyone know if adjustment the gear ratios for the transmission will effect the speedo output?????
    theoretically i could change the gear ratios in the trans to compensate for the tire size difference if it was part of the calculation
    2000 Dakota R/T
    gt45
    42lb
    honda map
    10psi
    Jan 2022
    912
    maybe if you start a couple more threads on it...
    I only started one. This forum is dead
    2000 Dakota R/T
    gt45
    42lb
    honda map
    10psi
    Dec 2023
    Did you ever test changing the transmission gear ratios?
