Originally Posted by
TransGo Robert
The transmission input shaft speed is a made up value that at time is no even close to being possible. Your computer is a 2002, even if the transmsision had been rebuilt with a 05-up pump and input shaft that use a turbine speed sensor there is no circuitry for it in the computer or wires for it in the vehicle's wiring harness. You can see how bogus the reading his on the first set of upshifts 1-2-3 where under moderate acceleration the input shaft is turning faster then the engine up to 2000+ RPM faster at a certain point which is only physically possible when you are coasting down, now on acceleration. The computer never commands lock-up so you can't ever calcutate the gear ratio accurately. Your 1-2 shift sure seems sloppy but without all the transmsision parameter it is a bit hard to say just how bad it is. We would need shift solenoid command and pressure solenoid command to better evaluate things. No matter what, unless the pressure command is all wrong, there is little you can do on those tuning wise to help a 4L60E shift quicker, it would need to be modified internally.
