Results 1 to 3 of 3
Thread: CLA45 M133 log help me,
    The last paragraph of the log does not lock the throttle valve, but there is a feeling of jamming. The ignition is very low, and the engine is running at low speeds and high loads, causing one jamming at a time,Do you have a good friend who can help me analyze the data flow
    Jan 2022
    13
    hi, post you tune too!!! in log if not a gear shift spark retard ??? if a gear shift retard, its normaly .... not a normaly when wot in middle rpm !!
    Jan 2022
    Southern California
    376
    You should add Knock Retard because it looks like it's retarding a lot. Eliminating knock retard made a big difference in my car
    I don't know what you mean about the throttle, or jamming
    '16 E550 Coupe RWD - C207.373 / M278.922 / MED17.7.3 / 722.909
