Results 1 to 5 of 5
Thread: 1.5 Ecoboost 2017 euro stoich
    Sep 2023
    15
    Hi friends.
    I'm new to tuning and recently bought MPVI3.
    In the firmware I saw that the stoich is 14.36 as for E5 fuel. My area doesn't use ethanol.
    Can I change 14.36 to 14.67 and continue using the car without any problems or need more adjustments in the firmware?
    Thank you
    1.5 ecoboost FV6A-14C204-TJ.hpt
    Sep 2023
    15
    Want to improve fuel consumption
    Jun 2022
    27
    I don?t know how that ECU works, BUT I wouldn?t do that.
    1. I guess the ECU makes its calculations based on that stoich: PE, Timings, Injection rate etc. Therefore I can imagine it maybe needs to be adjusted.
    2. I am just asking myself, how much fuel saving are you expecting? 0,5L each 100km?
    Jun 2019
    Wisconsin
    305
    The stoich ratio parameter just gets the ECU into the ballpark for fuel corrections, it will still target a 1.0 lambda and use LTFT to get there regardless of what stoich AFR is set to.
    Sep 2023
    15
    Thanks a lot, Ill try to find another way improve fuel consumption
