Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 80
Thread: EGR Enable not visible P59 ECU
  1. #41
    Oct 2004
    688
    Quote Originally Posted by slarsen47 View Post
    Thanks a million!
    Edit: I assume that the change was more than the EGR engage and disengage speeds? Would like to understand the change that I apparently could not do.
    There is a separate enable/disable flag that has to be set. You also need egr airflow and spark advance corrections to be zeroed out when using the egr input for something else. The newer versions of hpt don't seem to show those, although if you use ctrl n in your editor, you will be able to view the airflow and spark tables.
  2. #42
    Quote Originally Posted by gametech View Post
    Thank you!
    2002 Camaro SS LS1 D1SC 4L60e Yank 3600 Moser 9 inch 11.3 at 120 on 6 psi MT 255/50R16
    1998 Camaro Z28 LQ4 Huron T4 kit 4L80e Circle D Moser 9 inch...........runs n/a construction continues
  3. #43
    May 2023
    7
    needing egr turned on as well for mine please
  4. #44
    Senior Tuner 04silverado6.0's Avatar
    Sep 2021
    Kentucky
    1,848
    Quote Originally Posted by That1talon View Post
    Looks like it was enabled. The diag mph was raised so i lowered that.
  5. #45
    Banned
    Mar 2022
    Indiana
    4,289
    Correct your injector data
    https://forum.hptuners.com/showthrea...l=1#post796064
  6. #46
    May 2023
    7
    using a copy of one of sloppys tunes for 80lb dekas would be there different versions of 80lb dekas?
  7. #47
    May 2023
    7
    not being a smartass if it came off that way just genuinely curious bits a 5.3 swapped camaro if that makes any difference that table i see ls1 ls2 etc but nothing for 5.3
  8. #48
    Banned
    Mar 2022
    Indiana
    4,289
    There's a lot of Deka 80 "data" floating around out there. The one I linked works. I've used it on 3 tunes so far. Look on the first tab. That's who did it. Have to set Fuel>Transient>MinFuelMg to 0.010. 58psi fuel pressure.
  9. #49
    Sep 2021
    Kentucky
    1,848
    I would not follow anything from sloppy mechanics especially tuning related.
  10. #50
    May 2023
    7
    which table would you recommend for a 5.3 under the gm data then?
  11. #51
    Banned
    Mar 2022
    Indiana
    4,289
    The one that says GM data. LS1.
    0kPa column for all columns of IFR and Offset if vacuum-referenced.
    Set your O2 switchpoints to 451. Not going to get anything useful so far off at 301mV. Fix CL enable temp.
    Spark below 0.64 cylair should be put back to stock. Truncate with boost.
  12. #52
    May 2023
    7
    Have wideband im running post turbo and going open loop speed density do I still need to change the 02 switch points
  13. #53
    Banned
    Dec 2024
    214
    TunerPro or UniversalPatcher might be quicker than whatever you need to do for HPT. I use an OBDLink SX, $50 cable, niche free software. UniversalPatcher is only good for VPW era ECUs, and only a few of them. P01 and P59 mainly. There's some amount of support/work going into the P10 and 1 or 2 other 6 cylinder ECUs.
  14. #54
    Tuning Addict
    10,887
    Quote Originally Posted by MarcWolfe View Post
    For doing what, enabling the EGR (which is what this thread is about, with people stuck on newer software that has the EGR stuff removed posting their files so people who kept version 4.8.7 around can enable it for them)?
    You do realize this is the HP Tuners support forum and not just a general tuning site, right?
  15. #55
    Banned
    Dec 2024
    214
    You explained yourself, in the same comment, why it made sense to suggest looking into some free software to supplement his HPT woes.
  16. #56
    Dec 2024
    27
    Seems like this is the unofficial thread for EGR enabling... can any of you beautiful gentlemen help me out?
    -EDIT GOT IT GUYS THANKS
    570sx v3.hpt
  17. #57
    Oct 2004
    688
    Check your other thread.
  18. #58
    Dec 2024
    2
    Disable EGR
    Hello kind folks of the HPT community
    I am new here and just recently started tuning my truck. Would one of you kind souls help me out and DISABLE the EGR setting under the Exhaust tab, please?
    I simply don't see the option as my version is too new . I was thinking setting the disable to 255 and enable to 0 wouldn't be enough?
    Here's my tune file. 2001 gmc sierra custom.hpt
  19. #59
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    940
    Here Ya go
    2011 Camaro 2SS Convertible L99 Bone Stock for now
    2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
  20. #60
    Dec 2024
    2
    Quote Originally Posted by dhoagland View Post
    Here Ya go
    Thank you so much!
