Results 1 to 2 of 2
Thread: 8l90 2nd gear launch tune
    Aug 2005
    335
    How can we setup the 8l90 in a C7 Z so it launches in 2nd gear only at the track? I typically can do it manually but if I push the shifter to fast it will go right into N and that kills it.
    Thanks in advance!
    GO RAIDERS!!!!!!!!!!
    02 C5 Z06
    8.8@160
    Jul 2023
    2
    assuming you know how to set up the transmission to auto up shift in manual mode, you would just set up the tutd tables for a second gear start. then everytime you used manual mode you would have the second gear start, and if setup correctly you could leave it in manual mode , and it would auto upshift and the only thing you would have to do is down shift using the paddles.
